WestyLancs Posted May 11, 2012 Share Posted May 11, 2012 Just testing the water folks. Have an '06 R12RT, and stupidly managed to knock the windshield over, having taken it off the bike and propped it up whilst working on the front end. Bottom line is I now have a few small scratches on it. Nothing major - they look like small bugs that haven't been fully cleaned off. Question is, does anyone know of anything that will remove them, without too much expense, or bother. As I said above, they're no big deal, but more of an 'I know they're there' kind of thing. Link to comment
BerndM Posted May 11, 2012 Share Posted May 11, 2012 Cruise on over to your nearest regional airport and ask the guy in the parts store. There's a plastic cleaner/polisher that used on small airplane windows that should work for your. Link to comment
Skywagon Posted May 12, 2012 Share Posted May 12, 2012 Meguiars makes a polish for acrylic and airplane windshields that most likely take most of it out. It comes in two grits. If you use it several times it will eventually polish most of it out. My advice for windshields...Go buy cloth diapers...wash them..no softner..Usually 6 in a pack for about $12. They're getting a little hard to find, but there is nothing more gentle on your windshield. Rub one way..up and down. Been using that method on aiplane windshiels for 25+ years. Link to comment
dirtrider Posted May 12, 2012 Share Posted May 12, 2012 Evening Lan Before using anything more than a light cleaner on that windshield you need to find out if it uses a coated surface. A lot of motorcycle windshields use a coating on the windshield as protection against scratching. If your stock windshield has that type of coating & you use an abrasive on it you won't be a happy person. I don't know if the BMW 1200 is coated or not. Hopefully someone that has researched it will post here. Link to comment
WestyLancs Posted May 16, 2012 Author Share Posted May 16, 2012 Thanks for the replies guys. Having lived with it for a few days now, I think I'll leave it. Firstly as DR mentions, there may be some sort of anti scratch coating - don't want to make things worse. Secondly they're more like tiny 0.5mm diameter dents/chips in the surface and feel much deeper than scratches so would need quite some polishing to get out. Thirdly, as I mentioned I can pretend they're bits of dead bugs, and I look over the screen when riding, so not in my vision. Link to comment
