BrianM Posted May 6, 2012 Share Posted May 6, 2012 Did a valve check. Used inch feeler gages but converted everything to mm. Can anyone verify my calculations? Intake - .13 to .23 .127 with 5.50 shim, change to 5.45 (2 valves like this) .178 with 5.44 shim, leave alone. .127 with 4.45 shim, change to 5.40 Exhaust - .30 to .40 .014 with 5.27 shim, leave alone .014 with 5.295 shim, leave alone .013 with 5.23 shim, change to 5.20 - worth it? .013 with 5.175 shim, change to 5.15 - worth it? Thanks Link to comment
bobbybob Posted May 6, 2012 Share Posted May 6, 2012 Something looks wrong with your reported Exhaust valve measurements. MM or in. ?? Exh target range is .30-.40mm, you say they are at .014?? Link to comment
BrianM Posted May 6, 2012 Author Share Posted May 6, 2012 Whoops, left the exhaust in inches. Intake - .13 to .23 .127 with 5.50 shim, change to 5.45 (2 valves like this) .178 with 5.44 shim, leave alone. .127 with 4.45 shim, change to 5.40 Exhaust - .30 to .40 .356 with 5.27 shim, leave alone .356 with 5.295 shim, leave alone .330 with 5.23 shim, change to 5.20 - worth it? .330 with 5.175 shim, change to 5.15 - worth it? Thanks Link to comment
terryofperry Posted May 7, 2012 Share Posted May 7, 2012 Brian Two valves were .127 with 5.50 shims and replaced with 5.45 shims to increase clearance by .05. I understand that. One valve was .127 with 4.45 shim and replaced with 5.40 shim. Am I reading it wrong or did that lower the clearance or did you mean replaced with 4.40? Intake - .13 to .23 .127 with 5.50 shim, change to 5.45 (2 valves like this) .178 with 5.44 shim, leave alone. .127 with 4.45 shim, change to 5.40 Just trying to understand so I can do mine. Thanks for posting by the way, I;m trying to learn. Terry Link to comment
bobbybob Posted May 7, 2012 Share Posted May 7, 2012 After seeing how little (basically none) my valves changed from 6K to 16K miles, I wouldn't worry about the .33 exh clearance. Check them again at the end of the riding season....so easy to do. Bet they haven't changed a bit. Link to comment
BrianM Posted May 7, 2012 Author Share Posted May 7, 2012 Brian Two valves were .127 with 5.50 shims and replaced with 5.45 shims to increase clearance by .05. I understand that. One valve was .127 with 4.45 shim and replaced with 5.40 shim. Am I reading it wrong or did that lower the clearance or did you mean replaced with 4.40? Intake - .13 to .23 .127 with 5.50 shim, change to 5.45 (2 valves like this) .178 with 5.44 shim, leave alone. .127 with 4.45 shim, change to 5.40 Just trying to understand so I can do mine. Thanks for posting by the way, I;m trying to learn. Terry The current shim is a 5.45 change to 5.40 Thanks Link to comment
terryofperry Posted May 7, 2012 Share Posted May 7, 2012 Thanks Brian, that makes sense. Terry Link to comment
