RTme2 Posted December 16, 2005 Share Posted December 16, 2005 Not having ridden in a month or more, I came home from work today and decided to start the RT and get some gas moving through the fuel system. Started her up in the garage and immediately smelled gas. Never had a leak when I was ridding this fall but now have fuel dripping steadily behind the right foot peg. I can't take the tupperware off to investigate for some time due to work load, but I'm wondering what might be a likely culprit. Has anyone experienced this? Dave Link to comment
270 Posted December 16, 2005 Share Posted December 16, 2005 1) Quick disconnect O ring(s) 2) Full fuel tank/cold, warms up, fuel expands, leaves via the overflow. Hope for #2. Link to comment
RTme2 Posted December 16, 2005 Author Share Posted December 16, 2005 Allen, I wish for #2 but there was no time for the fuel to warm up. I only started it for a couple minutes on the center stand, if that. Dave Link to comment
peb Posted December 16, 2005 Share Posted December 16, 2005 I had this problem awhile back. Every mourning I would have gasoline on my right boot when I got to work. I tightened up the hose clamps on the two hoses on the right side, under the tuberware and it solved the problem of leaking gasoline. I hope this is all you have to do. Link to comment
270 Posted December 16, 2005 Share Posted December 16, 2005 It's not a big deal either way (clamps or O rings), but of course the beauty panel must be removed. Watch where the gas goes as it does leave a nasty stain as you probably know. Link to comment
