ElevenFifty Posted April 17, 2012 Share Posted April 17, 2012 Those of us without cruise control benefit from having some kind of 'throttle lock' device. For our machines these are all of the 'twist to lock' bar end variety. These guys have a cute little $20 option that works great. I took a small zip tie and ran it through the cutouts to create a clamp to very slightly tighten the tension on my RT and F650 bikes ... with this 'fine adjustment' in place, I give this device 5 stars. Very easy to set ... just use your forefinger and it's done ... Additional benefit is that gloves are just not an issue. IMHO this is a Koako-Throttlemeister killer. Cheap and it works! Link to comment
EffBee Posted April 17, 2012 Share Posted April 17, 2012 Nice gadget. Certainly easier than the bar-end CC's I've experienced. Does it seem to be causing any wear problems on the BMW heated grips? Link to comment
ElevenFifty Posted April 17, 2012 Author Share Posted April 17, 2012 Nice gadget. Certainly easier than the bar-end CC's I've experienced. Does it seem to be causing any wear problems on the BMW heated grips? Just installed it, but they come with little silicon rubber(?) bands that you can use between the lever and your grips. The purpose is to increase friction but on the F650 the vibration was a little too much even with the bank in place. That's when I used the zip tie to get it just a smidge tighter. DH Link to comment
Selden Posted April 17, 2012 Share Posted April 17, 2012 Neat. My RT came with a Throttlemeister, which works well enough, but is a PITA to engage/disengage without removing your hand from the throttle (I usually use my left hand). Did anybody notice the irony of the caption to the demonstration video: Always keep both hands on the handlebars. Link to comment
azkaisr Posted April 19, 2012 Share Posted April 19, 2012 I have one on the GS and it works well enough Link to comment
KDeline Posted April 19, 2012 Share Posted April 19, 2012 I have heard this can snap in two pretty easy. I don't have one so I don't know this first hand. Link to comment
Mr_Ed Posted April 20, 2012 Share Posted April 20, 2012 I have heard this can snap in two pretty easy. I don't have one so I don't know this first hand. Yep.... Mine broke after only it's second use but in all fairness it was a cold day so the material wasn't as flexible as it would have been. Link to comment
Bill Tracy Posted April 23, 2012 Share Posted April 23, 2012 EffBee, The silicone rubber band mentioned in other replies is installed over your heated grips and takes all the wear... +1 on this simple device. Link to comment
lawnchairboy Posted April 26, 2012 Share Posted April 26, 2012 how bout that? The GS I just bought came with one of those little doohickies on it already.... Link to comment
