CMAXX Posted December 13, 2005 Share Posted December 13, 2005 Have an 04 RT with over 44k miles. What type of shock(s) are people using to replace the stock ones? Most bang for the buck? Link to comment
Boffin Posted December 13, 2005 Share Posted December 13, 2005 Have an 04 RT with over 44k miles. What type of shock(s) are people using to replace the stock ones? Most bang for the buck? Welcome to the board The most popular fit is Ohlins, followed by Works. Basically anything except OEM will be a huge improvement. Although at 44K miles the cheapest would be used low/no mileage OEM from someone who swapped them out straight out of the dealer. Basically the OEM shocks are shocking in performance Cya, Andy Link to comment
Ken H. Posted December 13, 2005 Share Posted December 13, 2005 Basically the OEM shocks are shocking in performance Ho, ho, ho! Yeah, shockingly bad performance! Link to comment
Tank Posted December 13, 2005 Share Posted December 13, 2005 Will work for shocks HAHAHAHAHAAHAHAHAHA well i thought it was funny, i'm a savin my pennys, hopin santa thinks i've been good, or at least good anuff,, I've narrowed down to Works Performance... Link to comment
tom collins Posted December 14, 2005 Share Posted December 14, 2005 have the same model and have used the basic Works shocks on this and a previous model. very pleased, difference is very noticable. this time, i didn't wait for them to be worn out and changed at 12,000 miles, last time, about your milage. though not good to start out with, stockers are usually shot about 30,000 so you are due. you should be able to get a pair for about $1,000. tom collins Link to comment
Kitsap Posted December 17, 2005 Share Posted December 17, 2005 Second on the Wilbers. Link to comment
Mr. Frank Posted December 17, 2005 Share Posted December 17, 2005 Any sage advice on the relative merit of replacing the front or the rear first? Which one makes the greatest impact on ride? Link to comment
Ken/OC Posted December 17, 2005 Share Posted December 17, 2005 Second on the Wilbers. I'd give a third but mine are on order only. Will report at the appropriate time. Link to comment
Bill Dennes Posted December 17, 2005 Share Posted December 17, 2005 Rear. Likely the best prices to be had if bought in a set. Get ALL the farkles on the rear unit. Wilbers external compresswion damping adjustments ARE worth it. Link to comment
