JamesW Posted March 5, 2012 Share Posted March 5, 2012 Hi DR, and thanx again for the suggestion. I called a friendly VW dealer and for $18 purchased a pin kit which will be mailed to me. Also, checked with a BMW m/c dealer and no help. Link to comment
roger 04 rt Posted March 5, 2012 Author Share Posted March 5, 2012 Hijacking my own thread. Any ideas where I could get male and female connectors with pigtails for: Fuel injectors O2 sensor for 1150s Link to comment
dirtrider Posted March 5, 2012 Share Posted March 5, 2012 Afternoons Roger On the fuel injector connectors try about any up level auto parts store (those FI connectors are pretty universal across a lot of car lines). Or visit an auto junk yard & cut one off an automobile. On the 02 sensor connector that is going to be a bit more difficult. If you can match it up by looking there are many online terminal & connector suppliers. Otherwise maybe try your local BMW motorcycle dealer for an old take off 02 sensor, or wire harness. Or try calling "Dobeck Performance" as they use them on their Techlusion products. Link to comment
JamesW Posted March 5, 2012 Share Posted March 5, 2012 Hi Roger, Have you tried realoem.com/bmw/ ? Link to comment
Peter Parts Posted March 5, 2012 Share Posted March 5, 2012 Hijacking my own thread. Any ideas where I could get male and female connectors with pigtails for: Fuel injectors O2 sensor for 1150s About the injectors, I suppose you can always splice into the wire portion (or add connectors) since the signals in the wire are very robust and neither give nor take RFI being a low-impedance albeit inductive circuit. The very nice folks at Techlusion will sell you (or maybe just legitimate Techlusion owners like me) the connectors for the stock O2 sensor. I know Kent won't believe this, but the True and Pure Engineers at BMW switched connectors early in the last decade... some time... there's the fatty and there's the cigar-shape one and maybe more. But remember, there are secrets to soldering O2 sensors known only to the initiated. (Kidding aside, the O2 sensors are reputed to breathe through the wires in ways they don't cover in the basic soldering course). Ben Link to comment
roger 04 rt Posted March 6, 2012 Author Share Posted March 6, 2012 Jim, Ben, DR, Many thanks for the suggestions. That's plenty to work with. The O2 sensor connectors will come in handy in case anyone wants to try this. Link to comment
roger 04 rt Posted March 11, 2012 Author Share Posted March 11, 2012 Today I came across the following descriptive notes on the MA 2.2 on Anton Largiader's site. Motronic 2.2 - Incomplete notes - Notes from stefan.hegnauer@gmx.ch ... after a cold start (i.e. after reconnecting the battery), the Motronic puts some of its data to a static RAM which is not erased as long as fuse #5 and the battery are ok. After a warm start, a checksum is computed to see if the RAM contents are still valid. Seems like it is referring to adaptation values. RB Link to comment
Peter Parts Posted March 11, 2012 Share Posted March 11, 2012 Could be as little as the TPS anchor voltage(s) which all agree are thing(s) the ECU needs to learn. Ben Link to comment
roger 04 rt Posted March 11, 2012 Author Share Posted March 11, 2012 Could be as little as the TPS anchor voltage(s) which all agree are thing(s) the ECU needs to learn. Ben Yup, you could imagine a lot of things. But I haven't seen too many two byte DRAMs, nor checksums performed on such little data. As a fan of Occam's Razor, you'll be looking for the most likely fit to the data, requiring the fewest assumptions. That being the case, I haven't made any measurements, seen any data, or read any paper that would even hint that the Motronics aren't adapting ECUs which was the art of that time. So the most likely case is that even the 2.2 had adapting capabilities. Merely to close the loop on the O2 sensor the Motronic has to adapt. Since you're interested, it would be terrific if you devised some tests and took data to prove or disprove these abilitites. My aim is to offer ways to simply get the most out of these 10-15 year old bikes. RB Link to comment
Peter Parts Posted March 11, 2012 Share Posted March 11, 2012 Could be as little as the TPS anchor voltage(s) which all agree are thing(s) the ECU needs to learn. Ben Yup, you could imagine a lot of things. But I haven't seen too many two byte DRAMs, nor checksums performed on such little data. As a fan of Occam's Razor, you'll be looking for the most likely fit to the data, requiring the fewest assumptions. That being the case, I haven't made any measurements, seen any data, or read any paper that would even hint that the Motronics aren't adapting ECUs which was the art of that time. So the most likely case is that even the 2.2 had adapting capabilities. Merely to close the loop on the O2 sensor the Motronic has to adapt. Since you're interested, it would be terrific if you devised some tests and took data to prove or disprove these abilitites. My aim is to offer ways to simply get the most out of these 10-15 year old bikes. RB Roger - My bike is quite well sorted out (iridium plugs, generous valve lash, great exhaust pipework...) and runs fine and without any surging I can remember for years. So, my personal experience may be no guide for anybody else. Also as I have argued, there is little time spent on closed-loop mode esp if you have a throttle counter-force spring providing you with a light and responsive throttle feel (throttle movements about a dozen times a minute... that cancels the loop each time). For some months, I rode with an O2 switch (and a three-digit digital A/F meter). I'd say the map rides better than the loop. After all, BMW MUST have spend big bucks sorting it out, just as they have to do with a carb on a new model. BTW, a closed-loop is the one time no adaptation is needed (that's what the loop does), except in the sense that some near-term logic is needed. I'm sorry I ever mentioned "Occam" in the first place. My point was that it is easy to arm-chair speculate and attribute all kinds of brilliant smarts to these 20 year old very basic ECUs. So some caution seems in order. About DRAMs and checksums, the ECU must populate the axis of the map of TPS angles (based on the anchor points) and it just can't do that on the fly. Perhaps somebody like dirtrider can tell us what the granularity of the TPS axis is since I don't know. To answer your question, disconnect the O2 sensor and ride on the map. If you have surging, add Techlusion enrichment. A/F is not important enough to bother with - it makes no sense to try to dial-in some kind of optimum when all you want is something slightly fat and if you do that, you can't get more power or any other engine goal (except economy). Simple as that. Ben Link to comment
JamesW Posted March 11, 2012 Share Posted March 11, 2012 Hello Ben, I see your point and mostly agree. However, Roger has a very curious mind and he has succeeded in furthering our understanding of just how the motronic works. Also, remember that early on his aim was not to modify how the motronic works but to understand it and work within its parameters to allow it to better perform its function which he has done. He specifically ruled out the Techlusion as it modifies in order to perform its function. My mods to my bike have definitely circumvented the operation of the motronic in that I have disabled closed loop operation and I'm not 100% sure that this is the way to go even though I like the results, so far. Roger has not removed the O2 sensor but has instead installed a superior version which is the wideband sensor which is an improvement on the original narrow band concept, imo. I may yet follow his lead at least with the '04RT. Link to comment
roger 04 rt Posted March 12, 2012 Author Share Posted March 12, 2012 As an idea how prevalent adaptive lambda control is and when it all began ... Bosch was richly endowed with this technology, early in the game. From Wikipedia Articles on Bosch Jetronic and Motronic. Adaptive use of Lambda began in the 1980s onward. [edit]LH-Jetronic (1982–1998) Digital fuel injection, introduced for California bound 1982 Volvo 240 models. The 'LH' stands for German: "Luftmasse-Hitzdraht" - the hotwire anemometer technology used to determine the mass of air into the engine. This air mass meter is called HLM2 (Hitzdraht-LuftMassenmesser 2) by Bosch. The LH-Jetronic was mostly used by Scandinavian car manufacturers, and by sports and luxury cars produced in small quantities, such as Porsche 928. The most common variants are LH 2.2, which uses an Intel 8049 (MCS-48) microcontroller, and usually a 4 kB programme memory, and LH 2.4, which uses a Siemens 80535 microcontroller (a variant of Intel's 8051/MCS-51 architecture) and 32 kB programme memory based on the 27C256 chip. LH-Jetronic 2.4 has adaptive lambda control, and support for a variety of advanced features; incincluding fuel enrichment based on exhaust gas temperature (ex. Volvo B204GT/B204FT engines). Some later (post-1995) versions contain hardware support for first generation diagnostics according to ISO 9141 (a.k.a. OBD-II) and immobiliser functions. The 1995 and newer Volvo 940 vehicles are one such example. [edit]ML1.1 The Motronic 1.1 System was used by BMW from 1987 on motors such as the M20. The systems have the option for a lambda sensor, enabling their use with catalytic converter-equipped vehicles. This feedback system allows the system analyse exhaust emissions so that fuel and spark can be continually optimised to minimise emissions. Also present is adaptive circuitry, which adjusts for changes in an engine's characteristics over time. Some PSA engines also include a knock sensor for ignition timing adjustment[4], perhaps this was achieved using an external Knock Control Regulator. [edit]Mono-Jetronic (1988–1995) Digital fuel injection. This system features one centrally positioned fuel injection nozzle. In the US, this kind of single-point injection was marketed as 'throttle body injection' (TBI, by GM), or 'central fuel injection' (CFI, by Ford). Mono-Jetronic is different from all other known single-point systems, in that it only relies on a throttle position sensor for judging the engine load. There are no sensors for air flow, or intake manifold vacuum. Mono-Jetronic always had adaptive closed-loop lambda control, and due to the simple engine load sensing, it is heavily dependent on the lambda sensor for correct functioning. Link to comment
Peter Parts Posted March 12, 2012 Share Posted March 12, 2012 We're back to parsing texts. As I mentioned earlier, all feedback loops are adaptive systems. I see nothing in those texts or in the operation of the crude Motronic that obliges me to think there is more. Maybe there is more and maybe there isn't. And as far as I can see, which isn't far, there is no need to posit "learning" besides the TPS anchors. Doesn't anybody know for sure? How come after all these years, nobody is privy to the Motronic block diagram? I certainly don't know. Ben Link to comment
roger 04 rt Posted March 12, 2012 Author Share Posted March 12, 2012 Ben, There are many readers here. I understand what You see but from many weights of evidence for and the lack of any evidence against, it is clear that these ECUs are learning adapting systems. For those who want to think about changes to their systems, I hope this is all useful background to select good, cost-effective changes. ... And if it's not your cup of tea, that's okay. As they say, YMMV RB And PS, the block diagrams are in the Bosch Automotive Handbooks. Link to comment
roger 04 rt Posted April 23, 2012 Author Share Posted April 23, 2012 I've been running with an LC-1 and BoosterPlug, kind of a belt and suspenders approach. The LC-1 for Closed Loop and the BoosterPlug for Open Loop. For some time I have wanted to see how the LC-1 and Motronic performed without the BP shifting the stock Open Loop AFR tables 6% richer because I know that Adaptation Values get built from Closed Loop and get applied to Open Loop. Confirming it worked that way would mean that the BoosterPlug was a nice-to-have (since I own one), not a need-to-have. A key to these tests is a cold start, watching how the Motronic and LC-1 transition from cold (enriched and Open Loop) to warm (no afterstart or warmup enrichments, and Closed Loop). Therefore both tests were begun immediately after start and on the same course. (Note: In the upper chart, second half, I was modulating the throttle more than in the second half of the bottom chart. Otherwise, they are for the same course.) I got out for the first two of several rides. In the attached photo, you can see the first ride (top chart) after the Motronic is reset with no BP, and then a day later, the second ride. In the first ride after reset (in my theory, before the Adaptation Values referred to in the BMW Service manual can be rebuilt) you can see a lot of deviations from 13.8:1. If you look carefully on the left of the top chart you can see the mixture starting at about 12:1 and then watch what happens while the bike warms up at about the 3 minute mark (same point below). You can also see the histogram on the right, it being the distribution of all AFRs during the ride. In the below chart, second ride from a cold start, you can see better adherence to 13.8 and a tighter histogram. (Ignore the spikes that go to the top of the chart, they are Overrun Fuel Cutoff.) It also gets to 13.8 right away, before the bike has warmed up and before it can be in Closed Loop, in the first minute or so. (Notice the dips to lower AFRs, that's where I'm shifting!) The only surprise in the lower chart is the blip to 14.7:1 (Open Loop target AFR of the reset Motronic) between 1:40 and 3:20 minutes. This was after a stop sign and reacceleration, before CL had started and perhaps (my deduction) in an area of the Adaptation Values table that had not built sufficient data yet. I plan to make many more rides and watch this closely and will have some more data over the coming weeks. RB In the photo, there are two horizonal dotted lines. The top line is 14.7:1 (Open Loop Table before Adaptation) and the bottom line is at 13.8:1 (My AFR target set by the LC-1). Link to comment
