chrisz Posted December 2, 2005 Share Posted December 2, 2005 Hi, Winter is here in Ontario and I'm thinking about building a bike lift table. I'm tired of bending over a bike when working on it and thought a lift table would be nice. I have a bike jack ($100 from Costco), but its not quite usable for the RT, but if I could attach a platform to it, then maybe it can be used as a lift table. Anyone try this, or have any ideas/plans? Chris... Link to comment
RTP Rider Posted December 2, 2005 Share Posted December 2, 2005 Can't offer any insights on building, but I bought a lift table from Harbor Freight and I've been real pleased. When I bought it they had it on sale for $299, but it looks like its up a bit from that now. I like the stability and being able to wheel the bike on the table to different positions in the garage if needed. One of my RT-P's is up on it right now! http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=91764 Hope that helps.. might be better than building one.. Link to comment
randy Posted December 2, 2005 Share Posted December 2, 2005 you are correct about a year ago maybe a little longer someone posted drawings. I downloaded them but cannot find them I remember the simple concept two 3/4 4X8 sheets of plywood cut one into two 2X8 sections cut the other into two sections one 3X8 one 1X8 take the 1X8 section and cut into two 1X4 sections now take the two 2X8 sections and rip a slot 6" up at the 2foot and 6 foot mark now take the two 1X4 sections and cut a slot 6" up at the 1 foot and 3 foot mark now take the 2X8 pieces and place them with the 1X4 pieces and you have your basic box. Now take the other 2X8 section and put it on top and you have your platform. for a bigger i.e. more expensive unit get 3 3/4 4X8 sheets, and cut the height to 30"X 8foot and make the width 30" adjust everything accordingly. according the the plans I remember reading the author built the original 2X8 size, and then built the 30"X8 foot platform, and noted the bigger size was worth the cost. hope that helps finally I remember someone posted they made the leg portion i.e. the 1x8 sections go at 45 degrees to the platform using the two 1x8 sections and it made the platform a lot more secure. i wish i knew who to draw you a pic. once you saw the pic it made a lot of sense. Link to comment
Delboy Posted December 2, 2005 Share Posted December 2, 2005 I have a pdf of a bike lift if anybody wants it,pm me with your email address and i will forward it on. Regards Del Link to comment
ChrisE Posted December 2, 2005 Share Posted December 2, 2005 Something like this But I got rid of those and bought a Direct Lift Link to comment
