Rafigso Posted November 19, 2011 Share Posted November 19, 2011 Was about 28 degrees this am when I left for work. The tires felt real soft, as they should, it's cold. Anything to be careful of or to do that would heat the tires up quicker? Link to comment
Jim Moore Posted November 19, 2011 Share Posted November 19, 2011 Letting out 1-2 psi will make them warme up quicker. Link to comment
Quinn Posted November 19, 2011 Share Posted November 19, 2011 My dumb question: When should you check and adjust tire pressure? If you'd done it at 28 degrees this AM, it would climb up 10psi or more by this afternoon. On the other hand, if you waited until this afternoon, it would be 10 or more low tomorrow morning. Even lower if you go for a ride and get them warmed up in addition to the ambient temperature. Or should you just get real anal and adjust tire pressure throughout the day? ---- Link to comment
Rinkydink Posted November 19, 2011 Share Posted November 19, 2011 Check them (cold tire pressure) before your ride and don't worry about it, and enjoy your trip. Link to comment
upflying Posted November 19, 2011 Share Posted November 19, 2011 At 28 degrees F, I'd worry more about the road surface than tire pressure. Link to comment
Norm 88 Posted December 8, 2011 Share Posted December 8, 2011 Check them (cold tire pressure) before your ride and don't worry about it, and enjoy your trip. + 1 Link to comment
elkroeger Posted December 9, 2011 Share Posted December 9, 2011 OH - I thought this thread was about "TIRED and cold". I'm tired and cold. Link to comment
Norm 88 Posted December 9, 2011 Share Posted December 9, 2011 OH - I thought this thread was about "TIRED and cold". In my case its TIRED and Old.... Link to comment
Joe Frickin' Friday Posted December 9, 2011 Share Posted December 9, 2011 My dumb question: When should you check and adjust tire pressure? If you'd done it at 28 degrees this AM, it would climb up 10psi or more by this afternoon. Shouldn't swing that much. Assume you check in the morning at 28 degrees, and find your tires are at 40 psi. In the afternoon, the temp goes up to 60 degrees; if you let your tires cool to ambient (60F), they'll be at 43.5 psi. Significant, but not outrageous. FWIW I don't usually worry if my tires are a pound or two low on cold mornings; I'm not going to be pushing the bike very hard until late morning (when the roads and tires are warmer). Link to comment
