TREE Posted November 24, 2005 Share Posted November 24, 2005 Can anyone measure a new one for me ? I have a used spare , need to know how much material it has lost . Tnx. Link to comment
Stan Walker Posted November 24, 2005 Share Posted November 24, 2005 Is that for the '94 RS??? Original clutch still in it? If so, I wasn't ever able to find that number (for Jan's '96 RT). BMW redesigned the cluch in Dec 97 to give longer life and changed the thickness of the disc. BMW says that when you upgrade to this new disc you need to replace the pressure plate as well. For what it's worth, the thickness on the new disc I put into Jan's '96 RT this last summer was 5.79mm (0.231") Link to comment
Lone_RT_rider Posted November 24, 2005 Share Posted November 24, 2005 For what it's worth, the thickness on the new disc I put into Jan's '96 RT this last summer was 5.79mm (0.231") For the record, I measured the new one at 0.237" before I installed it a few weeks back at the ATL tech day. The old one was measured at 0.189" (installed) and 0.201" when not under compression. Since I was that far in while doing the spline lube, I decided to replace it anyway. The bike has 78,000 miles and the disk could have probably gone another 50,000 miles easily. Shawn Link to comment
TREE Posted November 24, 2005 Author Share Posted November 24, 2005 Thanks Stan. I have a spare RT disc with 5.7mm left on it, '96 I believe. Seller said there was 14K on it, sounds about right. My RS has 62K miles, need to do a spline check and lube this winter so I got some parts on hand now if I need them. Link to comment
Stan Walker Posted November 24, 2005 Share Posted November 24, 2005 Sounds like it's almost new. If you currently have any slipping at all I would also replace the clutch spring. It's fairly cheap. I would consider having the final drive pivot bearings on hand too. Even if they feel OK on the bike, they may need to be replaced once you get a look at them. Good luck Stan Link to comment
TREE Posted November 25, 2005 Author Share Posted November 25, 2005 I have all the clutch parts plus the flywheel from the RT. I heard some of the final drive bearings are hard to get, needle bearings maybe........ can't remember, Link to comment
georgem Posted November 25, 2005 Share Posted November 25, 2005 Try thiswebsite. He makes Bushings from 660 oillite bronze. This is where my money is going nexttime. http://www.RubberChickenRacingGarage.com Link to comment
Stan Walker Posted November 25, 2005 Share Posted November 25, 2005 He makes Bushings from 660 oillite bronze Actually I think he buys them from someone else. No matter. Anything he says is good is just that. He is a gold mine of professional level information on the IBMWR mail list. Always helpful. They are a bit more expensive than the roller bearings are. If I didn't already own a spare set of the roller bearings I would consider switching on my upcoming spline lube. There has been one report of them being perhaps too tight out of the package. I don't think I would let that deter me from ordering them. Stan Link to comment
