litigator Posted November 23, 2005 Share Posted November 23, 2005 I can see into my glove box if I lean forward. Last week a piece of paper blew out of it. Is it supposed to be open like that? Link to comment
Bob Palin Posted November 23, 2005 Share Posted November 23, 2005 I can see into my glove box if I lean forward. Last week a piece of paper blew out of it. Is it supposed to be open like that? Uh NO! There's supposed to be a lockable door over it! Link to comment
litigator Posted November 23, 2005 Author Share Posted November 23, 2005 Not from that angle. I can see in from the centerline of the bike under the dashboard. Link to comment
Ken H. Posted November 23, 2005 Share Posted November 23, 2005 If you are asking is the top edge of the glove box suppose to seal tightly up against the underside of the side faring? Probably yes, but most of them do not. Link to comment
litigator Posted November 23, 2005 Author Share Posted November 23, 2005 No, I'm talking about a three inch opening between the box and the fairing towards the centerline of the bike. Link to comment
bmwmick Posted November 23, 2005 Share Posted November 23, 2005 No, I'm talking about a three inch opening between the box and the fairing towards the centerline of the bike. There is a bezel that attaches to the box and seals to the rubber gasket on the door. Item #3 here: http://tinyurl.com/dvdwc Is that what you are missing? Mick Link to comment
Rob L Posted November 23, 2005 Share Posted November 23, 2005 You seem to be missing the upper part of the glove box, #1 in the link http://www.maxbmwmotorcycles.com/fiche/MainDiagrams.asp?mospid=47981 Link to comment
Rob L Posted November 23, 2005 Share Posted November 23, 2005 Link doesn't go to correct picture. Try looking under "oddments tray" and also the gasket under "cover left". Link to comment
litigator Posted November 23, 2005 Author Share Posted November 23, 2005 You nailed it, Mick. I don't have #3. Thanks guys. Greg Link to comment
Nevets Posted November 24, 2005 Share Posted November 24, 2005 THATS why I love reading this stuff!!! I'm also missing that from my 2003 RT-P, and assumed it would be something expensive to find and replace. It looks like it's under $10. Yahoo! No more crappy looking piece of plastic crammed in there! Thanks! Link to comment
KMG_365 Posted November 25, 2005 Share Posted November 25, 2005 That is pretty cool! Also, for those considering the radio-ectomy (on 2002-2003 R1150RT's), save the little plastic grommets that the top of the radio frame screws into and re-install them and the screws in the lower portion before duct taping the seam up tight and re-mounting the now empty "glove box". I didn't do this and when putting the top piece back on mentioned above, it drops down a bit too far. The seam between the two halves seals fine, but the top doesn't fully engage the gasket on the door flap and I get a bit of dirt and grime blown into the glove box through the (albeit small) top gap. Link to comment
