Willie Posted November 20, 2005 Share Posted November 20, 2005 Does anyone have a link that will show me how to remover the wheels from my '02 RT and show how to mount tires on the rims? I am thinking of tackling this task myself. Local Honda/Yamaha etc dealer won't touch a BMW and won't change tires for me unless I have the same tires front and rear. Other way to go is the BMW dealership and leave it there, but then I need to get a ride back if they don't have a loaner. Thanks, Terry Link to comment
leikam Posted November 20, 2005 Share Posted November 20, 2005 Do you have the tools to change tires and balance the wheel after you've changed the tire? This is something you can do yourself, but I wouldn't recommend it without the right equipment. However, simply removing the wheels is much easier and I've found that bike shops will often give you a much better rate if you bring them the wheels (with the old tires on them) and the new rubber. Perhaps its worth asking your BMW shop for a rate on this? Link to comment
Willie Posted November 20, 2005 Author Share Posted November 20, 2005 I don't have any... yet. I would get the proper tools if I choose to do the job. The shop will give me a better deal if I just bring in the wheel. Any help with the front wheel removal? Thanks, Terry Link to comment
Ken H. Posted November 20, 2005 Share Posted November 20, 2005 This drawing gives a general overview of removal of the wheel. Note that the calipers must be removed first. ISFA changing your own tires, at the minimum you must have access to tire changing and balancing equipment. One, but certainly not the only solution I recently posted about here - NoMar Tire Changer Link to comment
UberXY Posted November 20, 2005 Share Posted November 20, 2005 The owners manual covers front wheel removal. Rear, too. Link to comment
russell_bynum Posted November 20, 2005 Share Posted November 20, 2005 Check out the Oilhead Maintenance Manual over on iBMWR.org for complete instructions on how to remove the wheels. If you're chaning your own tires, You can get as fancy or as basic as you want. Bare minimum, you'll need 2-3 tire irons, some bits of plastic milk jug cut up to act as rim protectors, and a 2X10 to use as a bead breaker. At the other end of the spectrum you can get the automatic changers that the shops use. There are several options in between including a unit from Harbor Freight that you'll need to modify and/or purchase extra parts to prevent it from scratching your rims, and the NoMar changer than Ken posted. (Both work on the same idea, but the NoMar already has all of the bits added to prevent rim damage.) As for balancing...check out the Marc Parnes balancer. I've seen it used many times and it's a quality unit. Marc's a good guy, too. But to be honest...and don't tell anyone this or they'll make me turn in my roundel and spend eternity in the slow lane behind an old VW microbus...but I don't balance my tires. I've never bothered to do it, and never had problems....and that includes the track bike which has seen 160mph with absolutely no problems. Link to comment
Willie Posted November 20, 2005 Author Share Posted November 20, 2005 Thanks guys. Think I have everything I need to know now. Looks like I need to get some good tire irons. Not sure what I am going to do about balancing yet. I wish the Parnes balancer was more universal. Then I could just get one to use on all three bikes. Terry Link to comment
Wooster Posted November 20, 2005 Share Posted November 20, 2005 I wish the Parnes balancer was more universal. Then I could just get one to use on all three bikes. Terry, Parnes' balancer works for all bikes though you mite need extra cone; I use it on air/oil heads and have another cone for my XR. You'd benefit greatly watching these steps, wheel removal, tire change/balance. Some tricks include rocking brake calipers, prying open pads to help w/removal; after removing valve stems, soapy water around rim/tire helps "pop bead"; lastly, it's imperative to get tire's edges down into the rim's center before you can lever'em off. Balancing, in spite of daredevil Russell's nonhabit, is what most mortals do. Wooster oh yes, rockymountainmc sells trick tire irons with ergonomic grips Link to comment
eakins Posted November 21, 2005 Share Posted November 21, 2005 to get the brake calipers past the rotors & rims you need to open the master cyl top cap, then push the brake pads outwards to make room. Link to comment
David Sharpe Posted November 21, 2005 Share Posted November 21, 2005 The directions talk about a high volume air compressor. I have a $40 electric compressor to fill the tires. Will this do? Link to comment
FlyingFinn Posted November 21, 2005 Share Posted November 21, 2005 It might. After mounting the new tires you need to get the bead to set on the wheel. Sometimes this requires good volume of air "dumped" into the tire. Before the bead mounts, the air can blow by the tire and slow inflation will not work. But then again, sometimes the tire is pretty tight right away and it can be filled up slowly (like a $40 compressor will do) to seat the bead. If your compressor is too slow for the job, just take the wheels to closest gas station and pop the beads there. Then you can fine tune the pressure at home. -- Mikko Link to comment
Stan Walker Posted November 21, 2005 Share Posted November 21, 2005 pop the beads WATCH YOUR FINGERS, it would hurt like "h#ll" to pop the bead onto them. Also watch your eyes, wear eye protection or turn your head away. Stan Link to comment
Joe Frickin' Friday Posted November 21, 2005 Share Posted November 21, 2005 pop the beads WATCH YOUR FINGERS, it would hurt like "h#ll" to pop the bead onto them. "hurt" doesn't quite cover it; I'm thinking more like "severe crush injuries requiring an ER visit and possible amputation." If you're bracing the wheel with your hand(s), keep all of your fingers on the tread surface and away from the bead/rim gap when seating the beads. Link to comment
Pilgrim Posted November 22, 2005 Share Posted November 22, 2005 pop the beads WATCH YOUR FINGERS, it would hurt like "h#ll" to pop the bead onto them. Also watch your eyes, wear eye protection or turn your head away. Stan What Mitch said goes, also. In any case, you, too, could have an entry on my website HERE. Pilgrim Link to comment
Stan Walker Posted November 22, 2005 Share Posted November 22, 2005 Great read..... Glad my name isn't on there..... yet..... Stan Link to comment
