fwegerich Posted May 20, 2011 Share Posted May 20, 2011 FYI Just got the ijet nav remote form my 4g iPhone and I am happy with it. Check it out at http://www.buyijet.com/index.php/1-way-products/ijet-nav-elite-black.html Link to comment
Penforhire Posted May 20, 2011 Share Posted May 20, 2011 How is the volume control for you? I used an early iJet remote with an iPod and the volume was laggy, no response then too much, in each direction. Otherwise I liked the idea. Link to comment
Dave_C Posted May 21, 2011 Share Posted May 21, 2011 I have been looking for this, thanks for sharing Link to comment
russell_bynum Posted May 21, 2011 Share Posted May 21, 2011 How is the volume control for you? I used an early iJet remote with an iPod and the volume was laggy, no response then too much, in each direction. Otherwise I liked the idea. I had similar problems with a couple of different wireless remotes for iPods....I'd be very interested to know how well this works. Link to comment
Froggy Posted May 27, 2011 Share Posted May 27, 2011 I use the Ijet Nav for my Nano and it states that if not used within a certain amount of time it goes into bat.saver mode.When U hit a button it wakes up,there will be a delay then U can use the remote normaly. Link to comment
JayW Posted May 28, 2011 Share Posted May 28, 2011 I wish it had a "commercial skip" feature/button for use when listening to previously-broadcasted podcasts. If it did, then I'd order one now. Holding a button down for a guestimated extended time to fast forward through commercials is not practical on a motorcycle. Jay Link to comment
fwegerich Posted June 2, 2011 Author Share Posted June 2, 2011 How is the volume control for you? I used an early iJet remote with an iPod and the volume was laggy, no response then too much, in each direction. Otherwise I liked the idea. Worked pretty well. I just tried it out with my iPhone 4 during a quick 1500 mile ride Remote was working as advertised. The only issue I found was that it matters in which order you connect the iJet connector and the audio output. You should always connect the iJet connector BEFORE the audio output otherwise the iPhone select the iJet connector as the output source. Don't ask me why it does that but it will work perfectly whenever I connected the pieces in this order. Link to comment
