TowJam Posted November 13, 2005 Share Posted November 13, 2005 What is the best way to remove the servo-brakes warning sticker on the tank of my RT? It's already halfway off and I want to remove the remainder of it and the gummy residue - but without damaging the plastic. The sticker appears to be one of those "tamer resistent" stickers - it doesn't simply peel off with a hairdryer. Link to comment
eaglemike Posted November 13, 2005 Share Posted November 13, 2005 TJ, I've had some success with a product called "goof-off" removing stickers on several bikes. A little time, and elbow grease. then a lttle wax, better than new! All the best, Mike Link to comment
David_S Posted November 13, 2005 Share Posted November 13, 2005 I just picked at mine with my fingernails. Heating it helps to soften it a bit. I used WD-40 on a soft rag to remove the glue residue. Link to comment
TowJam Posted November 13, 2005 Author Share Posted November 13, 2005 I just picked at mine with my fingernails. Heating it helps to soften it a bit. I used WD-40 on a soft rag to remove the glue residue. My mamma always told me "don't pick at it.." but if I do, WD40 won't dull the plastic. Correct? Link to comment
David_S Posted November 13, 2005 Share Posted November 13, 2005 Nope wont dull it. Just be sure and use a soft cloth. A lot of folks spray the entire bike with WD when they store them. Link to comment
TowJam Posted November 14, 2005 Author Share Posted November 14, 2005 Nope wont dull it. Just be sure and use a soft cloth. A lot of folks spray the entire bike with WD when they store them. Cool - thanks! Link to comment
mwheels Posted November 15, 2005 Share Posted November 15, 2005 There is another product which I used to remove my sticker - it is called "Goo Gone" which is made by Magic American Corp (800-321-6330), and is sold at places like Walmart. I used it successively in combination with a hair dryer, but it still took a lot of effort; the sticker was for sure tamper-resistent. No harm to the paint finish and cannot tell the sticker was ever there. Link to comment
steve.foote Posted November 15, 2005 Share Posted November 15, 2005 Hair dryer, WD-40, a few fingernails and lots of good old fashioned cuss words. Make sure you wax the painted parts when you're done. Link to comment
Warren_H Posted November 15, 2005 Share Posted November 15, 2005 Like mwheels said Goo Gone is my first choice it's mild and it works. Link to comment
TowJam Posted November 15, 2005 Author Share Posted November 15, 2005 Hair dryer, WD-40, a few fingernails and lots of good old fashioned cuss words. Make sure you wax the painted parts when you're done. Using just my fingernail and WD40, I've managed to get about 75% of the sticker off. For some reason, what's remaining is really sticking firm. Guess it's time to pull out the hairdryer, get a bottle of Goo Gone and finish the job. I will give BMW some credit... I've owned 4 Hondas - each with more stickers than a NASCAR racer. Link to comment
TowJam Posted November 16, 2005 Author Share Posted November 16, 2005 Like mwheels said Goo Gone is my first choice it's mild and it works. Like a champ. I was able to get the remainder of the sticker off (don't ask me how - it'll make you cringe) and the used the GG to get the residual gum off. I probably would've saved a half hour if I'd just started with the GG from the beginning. Link to comment
RFW Posted November 16, 2005 Share Posted November 16, 2005 Run your tank down near empty, so the gas level is well below the sticker, then heat the sticker with a hair dryer. This will soften the adhesive enough that it should come off easier. Then take care of the residual adhesive with isopropyl alcohol which isn't a very good solvent, but it is safe for paint. ...and NO, there is no possible danger of a fire, and no, the isopropanol will not damage the paint in the slightest. Bob. Link to comment
steve.foote Posted November 16, 2005 Share Posted November 16, 2005 Alright, I'll bite. Why do you need to run the tank level down below the sticker? Link to comment
Jim VonBaden Posted November 17, 2005 Share Posted November 17, 2005 Alright, I'll bite. Why do you need to run the tank level down below the sticker? That is what I was wondering? Jim Link to comment
SkidMark Posted November 22, 2005 Share Posted November 22, 2005 I used a hair dryer and a plastic putty knife to scrap it off and then cleaned up the goo with Honda's Polish Cleaner in a spray can...worked perfectly not a mark left behind. Link to comment
Rider1200RT Posted November 23, 2005 Share Posted November 23, 2005 I just picked at mine with my fingernails. Heating it helps to soften it a bit. I used WD-40 on a soft rag to remove the glue residue. What he said Link to comment
