ttorborg Posted May 10, 2011 Share Posted May 10, 2011 I was doing my routine brake/clutch bleeding last night. Clutch and front brake control circuits went as expected. Then I started on the rear brake control circuits. The first bleeder seemed to have one or two very small bubbles no matter how slow I pumped the brake pedal or how much I bled the circuit. I kept the fluid supply topped off and never let it get below half empty. I noticed a wet spot on the tower that rises from the base of the first bleeder where the aluminum meets the black plastic cap. I wiped it a couple times. The second bleeded required a half a dozen quick pumps of the brake peddal to get any fluid moving and it seemed to have a lot of air in the brake fluid initially. I could never completely remove all of the air bubbles no matter how much I bleed the cuircuit. The third bleeder was like the first bleeder in that it ran clear with just a trace of a bubble. I then bled the first bleeder again and got it to a point where I had just a trace of a bubble. I put the gas tank back on and took the bike for a ride and the brakes seem operate fine. The brake fluid was clean for all bleeders since this operation was performed 18 months ago. I confirmed that I was bleeding the brake bleeders in the right order. I am concerned about the rear #1 bleeder tower being wet and the my inability to remove all of the air bubbles from any of the three bleeders. Any ideas or recommendations? Tom Link to comment
cris nitro Posted May 10, 2011 Share Posted May 10, 2011 When I did my rear control circuit, there was always a fine line of what looked like very little bubbles, no mater how many times I filled the cylinder and bled away. I actually went thru the complete 4 bleed cycle 3 times and could never get the bubbles to go completely away. So I put it all back together and the brakes feel great. I wouldn't worry about it. Link to comment
dirtrider Posted May 10, 2011 Share Posted May 10, 2011 Afternoon Tom Pretty normal (IF) you didn’t remove the bleeders screws and put some pipe sealer on the threads. A bit of air gets sucked into the fluid stream around the bleeder screw threads. Nothing to worry about as the air enters AFTER the ABS and internal brake system. Link to comment
