rocketbunny Posted November 8, 2005 Share Posted November 8, 2005 About to buy a R1200st and I need to transfer my RAM mounted GPS and XM radio to the new bike. My old mounting method won't work here. What are other people using? I was kinda thinking that something like this http://www.gpscity.com/item-npi-small-0....all/ramb252.htm through the mirror mount might work...? Link to comment
BobsST Posted November 8, 2005 Share Posted November 8, 2005 I used the Ram Base w/ 9mm hole and 45 degree offset at the base of the mirror. I transfered this from another bike and I think I had to slightly enlarge the 9mm hole with a drill. Link to comment
rocketbunny Posted November 8, 2005 Author Share Posted November 8, 2005 This one? http://www.gpscity.com/item-npi-small-plate-with-9mm-hole-base-and-1''-ball/ramb272.htm Any problems with clearances getting stuff on the ball? I'm going to need one on each mirror. Link to comment
BobsST Posted November 8, 2005 Share Posted November 8, 2005 Yep - that's the one. I'm using it on the left side with a Garmin Rino which is pretty small but no problems with clearing the windshield either in the up or down position. No problem with it hitting the tank bag either. There is a little less room on the right side because or the larger reservior. Link to comment
