JohnNorCal Posted November 5, 2005 Share Posted November 5, 2005 Last night I had my left side plastic off. I noticed that the hex-screw that attaches the lifting handle was backed out about 3/4 of the way and was finger-loose. I use the main stand almost all of the time. I don't want to think what would have happened if I tried to lift it and was left there holding a brushed metal handle with a bike on its right side. Maybe it was a fluke but you can check it by just removing the black side cover. Link to comment
Larsen Posted November 6, 2005 Share Posted November 6, 2005 Good find John, I will definitely check mine. Link to comment
twilmotte Posted November 6, 2005 Share Posted November 6, 2005 I think BMW must have changed (improved) the design in recent years? My '04 RT lift handle is anchored to the frame bracket with a large cotter pin and clip. Thanks for the post ... I never noticed the design of this very frequently-used part before! Link to comment
JohnNorCal Posted November 7, 2005 Author Share Posted November 7, 2005 No problem, I was saved the cost of a new front fender and a tail light by reading this forum. I thought that I would pass on what little I know. Link to comment
russell_bynum Posted November 7, 2005 Share Posted November 7, 2005 Yep. I found the same thing on my RT once, so now I check it at every 6K service. Link to comment
RFW Posted November 7, 2005 Share Posted November 7, 2005 Last night I had my left side plastic off. I noticed that the hex-screw that attaches the lifting handle was backed out about 3/4 of the way and was finger-loose. I use the main stand almost all of the time. I don't want to think what would have happened if I tried to lift it and was left there holding a brushed metal handle with a bike on its right side. Maybe it was a fluke but you can check it by just removing the black side cover. LOCTITE!!! Bob. Link to comment
ncsonderman Posted November 7, 2005 Share Posted November 7, 2005 Which screws back out on the front fender and the taillight assembly? That'll be something for me to check Link to comment
JohnNorCal Posted November 7, 2005 Author Share Posted November 7, 2005 The whole tail light assembly is held on by two plastic knobs that you reach by taking off the rear seat and feeling with your fingers. They work themselves loose after a while. Don't use locktite on these! The front fender has four screws; two on top and two on the sides. I put blue locktite on these screws and always check after getting a new front tire. Link to comment
HoMa506 Posted November 7, 2005 Share Posted November 7, 2005 The whole tail light assembly is held on by two plastic knobs that you reach by taking off the rear seat and feeling with your fingers. They work themselves loose after a while. Don't use locktite on these! I used a lock washer on each of these and haven't had a problem since. Link to comment
