N51AM Posted February 9, 2011 Share Posted February 9, 2011 Does anyone have the measurements for the wooden blocks that are installed in the caliper to keep the pucks from moving in? Front and rear. I have seen it somewhere but can't remember.. Link to comment
johnlt Posted February 10, 2011 Share Posted February 10, 2011 I just used a couple pieces of wooden shingle. One coming in from each side. You could also just make some wedges on a saw that would work fine. Link to comment
Joe_C Posted February 10, 2011 Share Posted February 10, 2011 Here's the dimensions: Front block 3.0" x .43" x 1.25" (two per front caliper) Front block 3.o" x .86" x 1.25" (one per front caliper) Rear block 2.75" x .43" x 1.125" (two on rear caliper) Link to comment
BerndM Posted February 10, 2011 Share Posted February 10, 2011 Go to Home Depot or Lowes and get a pack of PLASTIC door/window frame wedge shims. They are nice and long and have a perfect smooth taper to them. Slip them in from opposite ends and they smoothly force the pads into their bores. Cost about $1.99 and reusable over & over. Link to comment
