austavla Posted February 9, 2011 Share Posted February 9, 2011 Hi, from Norway Is there someone who has manage to use the BMW (Clarion RCB-021-100) handlebar remote control with an aftermarket Clarion stereo? Best Regards Audun Link to comment
dirtrider Posted February 9, 2011 Share Posted February 9, 2011 Morning Audun I know this won’t directly answer your question but will maybe help you figure it out with some research. I have used the factory handlebar radio remote controls on two (non BMW) motorcycles to control aftermarket radios. The radios I used were a single wire input so it was fairly easy to make the factory controls work. With the single wire aftermarket radio inputs the control is through different resistance inputs. First I researched the radios I used to determine what resistance input was used to make the radio do what. Then I made up a simple flow chart using the desired output from the handlebar controls with series or parallel resistors to achieve the radio input I needed. Then I added all the resistors in a little handy box to house all the circuits, then just wired it in between the radio and the handlebar controls. On both bikes I did the handlebar control to the aftermarket radio I was extremely happy with the control functions with almost all the handlebar functions working the proper thing on the radios. Seeing as the radios had more functions than I had switches for I did have to eliminate a few radio remote control functions but those were doable through the radio buttons if needed. Link to comment
austavla Posted February 11, 2011 Author Share Posted February 11, 2011 Thanks for the tip D.R Audun Link to comment
