VinnyR11 Posted February 1, 2011 Share Posted February 1, 2011 Far too often I hit the CAPS LOCK key while I'm typing, so my stuff loOKS LIKE THIS and then I have to go back to correct it. Is there a simple way to assign keys to other letters/functions? I'd like to swap my Caps Lock with the "tilde".. this thing>> "~" Link to comment
Dennis Andress Posted February 1, 2011 Share Posted February 1, 2011 It could be done, but not simply. I might be easier to just pop the Caps Lock key off so as to get it out of the way. Link to comment
PLW Posted February 1, 2011 Share Posted February 1, 2011 Kind of like what I did with the num lock key since I had the same problem on that end of the keyboard. Link to comment
johnlt Posted February 1, 2011 Share Posted February 1, 2011 My new logitech back-lit keyboard allows you to disable certain keys. The cap lock key is one of them. Link to comment
VinnyR11 Posted February 2, 2011 Author Share Posted February 2, 2011 It could be done, but not simply. I might be easier to just pop the Caps Lock key off so as to get it out of the way. Nice and simple. That's the way I went, and it's still easy enough to use the cap lock when I want. Thanks. Link to comment
leikam Posted February 2, 2011 Share Posted February 2, 2011 There's a little utility program you can download called "KeyTweak". I wanted to disable the Windows key and this did the trick but it will also allow you to remap any other keys you want. No affiliation, no warranty, etc. Link to comment
Jerry Johnston Posted February 2, 2011 Share Posted February 2, 2011 You wouldn't want to do that on an Enermax keyboard it's a real PIA to put back on. Most however it quite simple. Link to comment
VinnyR11 Posted February 3, 2011 Author Share Posted February 3, 2011 You wouldn't want to do that on an Enermax keyboard it's a real PIA to put back on. Most however it quite simple. Mine was a snap. Literally. It just snapped up and then slid out along two wire guide posts. Link to comment
