KDeline Posted December 19, 2010 Share Posted December 19, 2010 Getting another labtop, want to put my current Mapsource in it, but no DVD because I have downloaded the updates. The last disc I have is from 2006. How do you transfer it, then run the setup? Link to comment
bmurphypdx Posted December 19, 2010 Share Posted December 19, 2010 Just a thought. Often when downloading, the downloaded file (install program) is saved to the hard drive. You might not even know it is there. If you are running Windows XP, look under My Documents and then in the Downloads folder. I see that I have a 56MB Mapsource file there (Mapsource_6162). Hope that helps. Link to comment
Starfighter Posted December 19, 2010 Share Posted December 19, 2010 Go to Garmin site with new computer. Connect your GPS using web-updater.. When it says you have the current map, select "download anyway." It will then download mapsource to your computer. Link to comment
99Roadster Posted December 20, 2010 Share Posted December 20, 2010 You'll need to install it from the original disc with the registration code and then update it and the map. If you don't have the CD contact Garmin and they can send you a link to the download. Link to comment
flars Posted December 20, 2010 Share Posted December 20, 2010 "...You'll need to install it from the original disc with the registration code and then update it and the map..." Pretty sure this only pertains to City Navigator (i.e. the map set). Mapsource, the routing software, is free. Pretty sure Starfighter has it right. Link to comment
Capt_Steve Posted December 20, 2010 Share Posted December 20, 2010 Get a USB flash drive copy cd to flash then flash to new laptop Link to comment
