Voyager Posted November 2, 2005 Share Posted November 2, 2005 From the liquid squirting past the dust boot on my forks I have deduced the time is right to replace the fork seals. I looked up the procedure in Haynes and it appears relatively simple for the home mechanic. Any cautions, equipment list, special tools or improvised household items that might serve as a seal driver? I have new seals & dust boots but haven't bought the fork oil yet. Thanks! Link to comment
hootowl Posted November 2, 2005 Share Posted November 2, 2005 I changed out the fork seals on my 1100GS this spring. It is an easy job. I used a 1 7/16 inch socket for a seal driver. A pair of circlip (snap ring) pliers for the seal retaining clip will be neaded. Link to comment
Brian PDQ Signs Posted November 2, 2005 Share Posted November 2, 2005 I had some difficulty with removing the forks from the triple tree. Up top I had to grind down a wrench to fit in between the top of the fork and triple tree. I didn't take the plastic off but did remove both forks and cleaned them up like new. I did have to purchase a long T handle allen wrench for the bottom bolt in the forks. Other than the top part of the triple tree problem it was an easy job. Link to comment
Ken H. Posted November 2, 2005 Share Posted November 2, 2005 It's easy. Some people do them one at a time on the bike. Drop and rotate one out front while the other stays in place to 'pivot' around. Link to comment
Voyager Posted November 2, 2005 Author Share Posted November 2, 2005 Thanks Brian and Ken. Good tips. I've been wanting some T-handles anyway Link to comment
Brian PDQ Signs Posted November 2, 2005 Share Posted November 2, 2005 FYI - I just checked and the T handle is a 5.0 mm allen wrench and about 9 inches long. Now you don't have to get the entire set just the 1 Link to comment
