RoyTemple Posted November 2, 2005 Share Posted November 2, 2005 I just tried hitting the left and right turn signal switches on my R1200RT and sure enough, the emergency flashers came on. However, I could not turn them off with the turn signal canceling switch. The only way I could do it was to press the red emergency flasher switch on the top of the left handlebar. Is there another way to turn them off? Link to comment
Jeff98362 Posted November 2, 2005 Share Posted November 2, 2005 Disconnect the battery...? Link to comment
steve.foote Posted November 2, 2005 Share Posted November 2, 2005 Disconnect the battery...? I was thinking cut the wire. Link to comment
RoyTemple Posted November 2, 2005 Author Share Posted November 2, 2005 Well actually, shutting off the ignition works also but I was hoping there was something where I would not have to remove my hands from the bars. Oh well Link to comment
Leo Flor Posted November 2, 2005 Share Posted November 2, 2005 I am away from my bike so I can't try it. I am not sure but I thought if you clicked on either turn indicator it would cancel your emergency flashers. Link to comment
Jim VonBaden Posted November 2, 2005 Share Posted November 2, 2005 I am away from my bike so I can't try it. I am not sure but I thought if you clicked on either turn indicator it would cancel your emergency flashers. That doesn't work in my 12GS. The only way to turn them off is the emergency flasher button. Jim Link to comment
Ken H. Posted November 2, 2005 Share Posted November 2, 2005 It was a mid-year change on the CAN-BUS bikes. Turn them off the same way you turned them on, or use the cancel switch. The flasher button is gone all together for '06. Link to comment
dyvking Posted November 3, 2005 Share Posted November 3, 2005 I just tried hitting the left and right turn signal switches on my R1200RT and sure enough, the emergency flashers came on. However, I could not turn them off with the turn signal canceling switch. The only way I could do it was to press the red emergency flasher switch on the top of the left handlebar. Is there another way to turn them off? Hmm.. on my '06 the turn-signal cancel switch also shuts off the emergency flashers. However, it also works to press the left and right turn signals simultaneously, as you do to actuate the emergency flasher in the first place. Link to comment
