Nesbocaj Posted December 2, 2010 Share Posted December 2, 2010 How do you all change the oil on the trany without getting it all over the place? I tried a way used on the FJR's, aluminum foil leading into the basin but still made a bit of a mess. Link to comment
dirtrider Posted December 3, 2010 Share Posted December 3, 2010 Evening Nesbocaj I take an old 1 gallon plastic milk or water jug and cut a slice about 1/2 of the diameter out of it. Leave a piece of the bottom on to hold the shape and give you something to prop it in there with. That also keeps the oil from flowing out the top end. If done correctly you can use that as a trough to guide ALL the gear oil out and into a drain pan. You need to jam it up in there under the drain plug hole and terminate it in the drain pan. If you play around with it a little you will see how to make it work. Link to comment
Nesbocaj Posted December 3, 2010 Author Share Posted December 3, 2010 Good idea thanks Link to comment
hopz Posted December 3, 2010 Share Posted December 3, 2010 You can easily make a "funnel" from any non-absorbing material. I use a regular plastic funnel. I have seen others use a plastic document protector funnel taped together... Link to comment
timboaz Posted December 4, 2010 Share Posted December 4, 2010 NAPA is now selling a "funnel" device that can be formed to just about any shape. I have only seen ads in magazines, but plan to get one before the next change. Link to comment
hopz Posted December 5, 2010 Share Posted December 5, 2010 check this out... http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=131174&page=1 Link to comment
Nesbocaj Posted December 6, 2010 Author Share Posted December 6, 2010 check this out... http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=131174&page=1 Looks like the sheet protector works, wonder why the tin-foil didn't? I didn't have it on the sidestand though.....maybe.... thanks Hopz Link to comment
brianbmw Posted December 21, 2010 Share Posted December 21, 2010 Buy your oil from beemerboneyard. There trans and final drive fluid bottles have an internal straw that pulls out of the bottle. I used to struggle with a good solution to this problem all the time, not anymore. Besides you'll probably save a few bucks on the cost of the maintenence kit. Brian Link to comment
hopz Posted December 21, 2010 Share Posted December 21, 2010 If you lay the bike on its left hand side it will fill even easier... one quart only. Link to comment
