steve539 Posted November 1, 2005 Share Posted November 1, 2005 Has anyone adjusted the 05 RT shifter lever? It looks like you have to remove the left side foot peg bracket and then adjust. The shop CD doesn't deal with this issue ( that I can find). Link to comment
h2000fb Posted November 1, 2005 Share Posted November 1, 2005 You are correct. I adjusted mine and that is exactly what you have to do. By the way, I ended up putting it back where it was!! Link to comment
Jon_M Posted November 1, 2005 Share Posted November 1, 2005 I don't follow this. When I adjusted mine, I reached behind the panel the footpeg is attached to and popped off the turnbuckle, adjusted it, and put it back on. It took two or three tries to get it right, but was not a difficult job. I actually did this twice, first to give enough room for the toe of a new boot, and the second time to adjust for the footpeg lowering kit that I installed. Link to comment
