essman Posted November 25, 2010 Share Posted November 25, 2010 Does anyone know if you can get the starter solenoid from a parts supplier. Bench testing it, I can make the starter run, but the solenoid does nothing. There are some numbers on the solenoid, but I can't link them to a part number--Thanks Link to comment
Sailorlite Posted November 25, 2010 Share Posted November 25, 2010 I suspect you might not be able to get just the solenoid. But, who is the manufacturer - Bosch, Valeo, other? What are the part numbers on the solenoid itself? With that info I would do a Google search and see what happens (if you haven't already). Also, you could check with Beemerboneyard.com to see what they might have. Link to comment
NewBlue Posted November 25, 2010 Share Posted November 25, 2010 I never looked at the RT starter but if the starter solenoid is not the pull in type that also engages the drive as well as the motor. you can purchase an external relay rated for the starter amps and remote mount it. Link to comment
Beech Posted November 25, 2010 Share Posted November 25, 2010 Also try , http://www.mesmotorcycle.com/street.htm http://www.motoelekt.com/ And this very well may be it??? http://www.euromotoelectrics.com/product_p/val-sol2.htm (tech help is improved with model and year of bike) Link to comment
farmerp Posted November 25, 2010 Share Posted November 25, 2010 I took my alternator to an auto electric shop and they fixed it the same day. Might be worth a try for your solenoid. Link to comment
dirtrider Posted November 25, 2010 Share Posted November 25, 2010 I never looked at the RT starter but if the starter solenoid is not the pull in type that also engages the drive as well as the motor. you can purchase an external relay rated for the starter amps and remote mount it. Evening New Blue On the BMW 1100/1150/1200 boxer the starter solenoid is mounted on the starter so it pulls the starter drive into flywheel engagement using a plunger and fork affair at that time also powering the starter motor. Link to comment
NewBlue Posted November 26, 2010 Share Posted November 26, 2010 I never looked at the RT starter but if the starter solenoid is not the pull in type that also engages the drive as well as the motor. you can purchase an external relay rated for the starter amps and remote mount it. Evening New Blue On the BMW 1100/1150/1200 boxer the starter solenoid is mounted on the starter so it pulls the starter drive into flywheel engagement using a plunger and fork affair at that time also powering the starter motor. Happy Thanksgiving dirtrider Makes sense with the engine trans arangement on this bike Thanks Link to comment
essman Posted November 26, 2010 Author Share Posted November 26, 2010 On the BMW 1100/1150/1200 boxer the starter solenoid is mounted on the starter so it pulls the starter drive into flywheel engagement using a plunger and fork affair at that time also powering the starter motor. Happy Thanksgiving dirtrider That's how it looks like it works, it looks very similar in looks and setup to the Valeo, but this is a Bosch starter and it seems to be unique to the 1200RT--which I don't understand why they would have to do that. The uniqueness makes it harder to find a used one that fits. B-Boneyard doesn't have a used one right now. The only numbers that I could find on the solenoid were 40623486 and the 6s might be 8s. It was very hard to read even with a magnifying glass as it almost looked double struck. Taking it to an electrical shop may be a good start--no pun intended. BMW wants $460 for a new one and the cheapest used starter I can find is about $230. I just got this RT for a very reasonable price, but it was stored for four years in a damp climate so I am dealing with corrosion issues and the fluids, especially the gas, were just awful. I am not even trying to get the bike running until a lot of things get sorted out---good winter project. Thanks--Mark Thanks Link to comment
