Husker Red Posted October 28, 2005 Share Posted October 28, 2005 I have a Z1R vented leather jacket I really like, but I would like to add armor to it. There are no pockets for armor now. It does have a mesh liner attached to the inside of the leather. Any suggestions? Mike Link to comment
David Sharpe Posted October 28, 2005 Share Posted October 28, 2005 Icon sells slip on armour. Link to comment
Brian M Posted October 28, 2005 Share Posted October 28, 2005 you might find something at http://www.actionstation.com/ Link to comment
Haynes Posted October 28, 2005 Share Posted October 28, 2005 An experienced clothing maker should be able to put armour in for you. Before you get it done, you'll need to ensure that the shape of the jacket will not allow the armour to move during a fall. Link to comment
jgrant Posted October 28, 2005 Share Posted October 28, 2005 Dainese sells armor you can wear. So does ICON. So do a lot of other brands. I would recommend you go that route. It also gives you the ability to wear the jacket off the bike without removing the armor. How much room is there under the jacket now? Link to comment
Husker Red Posted October 30, 2005 Author Share Posted October 30, 2005 The jacket is loose enough that I could put armor in it and it should still fit well. I want to use it as my commuter jacket - put it on over my shirt and tie and away I go. I saw the loose armor that can be added to the pre-made armor pockets, but my jacket doesn't have those. Perhaps a tailor could add them? Probably would be cheaper just to get another jacket. Thanks for the replys so far, Mike Link to comment
John Dickens Posted October 31, 2005 Share Posted October 31, 2005 You could use an armoured mesh inner shirt such as Dianese and others make but my advice would be to use Hein Gericke Hyprotec armour which can be fitted to the lining of any clothing using a 'popper' type system. I've used it a couple of times and it works well. You can also sew it in if you wish. Link to comment
