laska77 Posted October 16, 2010 Share Posted October 16, 2010 My left signal lights stopped working recently the bulbs are good, flashers and wiring okay. I believe it's in the switch but can't figure out how to remove it. Anybody have a parts list so I can see the disasembly process. Got up to certain point and then couldn't find any other screws to complete the process. Any suggestions or a parts list would be nice. Link to comment
BarOne Posted October 16, 2010 Share Posted October 16, 2010 There is a white sticker that is revealed when you remove some of the parts. Peel the sticker back and there is an additional screw under it. It's a bugger to get the thing apart and get the switch out / repaired. Good luck. Link to comment
BeemerLover Posted October 16, 2010 Share Posted October 16, 2010 Had a similar problem on an R1200C years ago. The switch was dirty or had some water in it. I sprayed it with electrical contact cleaner and worked it good and it started working again. Shouldn't hurt the plastic but test that first. If the switch feels right when you click it then there is a good chance it is just dirty or wet. But then again it might be broken. Might save some time... Link to comment
notacop Posted October 17, 2010 Share Posted October 17, 2010 I did some switch gear cleaning on mt RTP. It can be done if you are careful. Link to comment
