DallasR1100RT Posted October 12, 2010 Share Posted October 12, 2010 So I found the wire that caused the fire...green with red stripe. Looks like it goes to the dash lights on the right. After the main wiring harness change the gear indicator light does not display the gear. Could that green with red stripe wire be the gear dispaly? Any idea what could be the issue with no gear indicator? Mark Link to comment
oldyam Posted October 12, 2010 Share Posted October 12, 2010 Hi Mark The only Green / red stripe I can see on the Haynes diagrams goes from the Sidestand switch to the kill switch on the R1100RT. The wiring from the gear sender to the RID is:- Solid brown, yellow / black?, yellow / white & yellow / green Hope this helps Link to comment
Edgar Posted October 12, 2010 Share Posted October 12, 2010 Is your bike up and running? Link to comment
DallasR1100RT Posted October 12, 2010 Author Share Posted October 12, 2010 Yes Sir...the Phoenix is running. Rode her home last night. The gear indicator is not working...but other than that...she seems fine. Link to comment
DallasR1100RT Posted October 12, 2010 Author Share Posted October 12, 2010 Thanks Nigel Link to comment
Edgar Posted October 13, 2010 Share Posted October 13, 2010 There is one more connector. On the original harness there is a plug that is strapped to the frame by the left black removable triangle. Find the cable that runs from the switch on the back of the transmission toward the back of the bike (left side). It's a 4 wire cable that has a oval plug. Match up these bad boys and you will have your gear indicator. Link to comment
