Bingo Posted October 11, 2010 Share Posted October 11, 2010 I was doing some work on my 2000 r1100rt, and upon finishing I realized I had a vacuum line going to nowhere. It is about half the diameter as all the other lines and runs from the right rear around the airbox and back to the left rear(I think). Maybe it's a drain line. I don't have a clue/ Thanks for any help it's the last little job to fix before I take her for a spin. Link to comment
Boffin Posted October 11, 2010 Share Posted October 11, 2010 At a guess I would say it is a battery vent line - these would be in that general area and are often left when a wet battery is replaced with a Gel or AGM sealed battery that does not use a vent. Andy Link to comment
NonComp Posted October 11, 2010 Share Posted October 11, 2010 +1 on the drain line for older style lead-acid batteries. I found a similar orphaned line. Running into the battery box. Link to comment
Bingo Posted October 11, 2010 Author Share Posted October 11, 2010 OK good enough thanks for the help! Link to comment
