byekurman Posted October 8, 2010 Share Posted October 8, 2010 My fog light fuse keeps blowing. Any folks out there had this problem? Ideas? Link to comment
Quinn Posted October 8, 2010 Share Posted October 8, 2010 Wire shorted to ground? With fuse removed, take a continuity reading to frame ground; with and without switch thrown. Anything else on same fuse? Does it blow if you don't have the fog light on? With fog light bulbs removed? I'm guessing you have a wire rubbing on the frame somewhere causing a short. --- Link to comment
byekurman Posted October 8, 2010 Author Share Posted October 8, 2010 Thanks Quinn I will try to check out what you suggest. I have some of the tupperware removed to investigate battery power issue. I guess that I will have to remove more stuff to get a better look. Link to comment
Quinn Posted October 10, 2010 Share Posted October 10, 2010 Any luck? Guess I should have asked if it blew the fuse immediately or intermittenly. --- Link to comment
