canoehead Posted October 26, 2005 Share Posted October 26, 2005 I'm working on a 2001 1150GS project bike. Among other things, the oil cooler got dinged and has a small leak. I'd read in an article discussing some of the design that went inot the GS that it has an oil cooler "borrowed" from the RT. From the research I've done, it would appear the GS/RT part numbers for the cooler units are different. Can anyone tell me if there's a possibility of RT cooler bolt on to a GS, either directly or with a bit of modification? Failing that, could a rad shop do a repair to an oil cooler with a pinhole leak? thanks for any guidance Rolf Link to comment
Ken H. Posted October 26, 2005 Share Posted October 26, 2005 I think the mounting to the sub-frame is different. Not to say that it might not be adaptable, but it would probably be easer to find the right one. They should be readily available on the salvage market. Link to comment
Geoff2 Posted October 26, 2005 Share Posted October 26, 2005 I am pretty sure its from R1100RT on a 1150GS, but don't quote me Link to comment
canoehead Posted October 27, 2005 Author Share Posted October 27, 2005 It would probably be easer to find the right one. They should be readily available on the salvage market. I'd prefer to put the right one on, but the only oil cooler I've found on the salvage market is from an RT, hence the question. Any pointers to sources for used parts? Link to comment
Slartidbartfast Posted October 27, 2005 Share Posted October 27, 2005 Failing that, could a rad shop do a repair to an oil cooler with a pinhole leak?Go and talk to a rad shop. Take the rad with you - a pinhole leak in an otherwise sound all-metal radiator should be a trivial repair for them. One of my friends got a holed K75 radiator repaired for about five bucks. Link to comment
canoehead Posted October 28, 2005 Author Share Posted October 28, 2005 Mike Figielski at beemerboneyard.com just confirmed for me that the mounts for an RT oil-cooler are different enough from the GS that it won't just bolt on, even though the cooler itself is similar enough in size. Anybody know of other salvage sources that might have parts? thanks Link to comment
