madness522 Posted October 26, 2005 Share Posted October 26, 2005 With the cooler weather the RT is harder to start after sitting outside all day waiting on me to finish working. I checked the voltage as soon as I pulled into the garage and it showed 13.0 so I hooked up the trickler charger and checked again once it went into maintainence mode and it showed 13.3. Is it time for a new battery? Link to comment
Ken H. Posted October 26, 2005 Share Posted October 26, 2005 Sounds about right. But static voltage drop isn't everything. A better indicator is what does the voltage drop to while the bike is cranking? Anything below say 11.5v or so may support the idea that the battery is on the way out. BTW, you do pull the clutch lever when cranking a cold bike, yes? Link to comment
madness522 Posted October 26, 2005 Author Share Posted October 26, 2005 Sounds about right. But static voltage drop isn't everything. A better indicator is what does the voltage drop to while the bike is cranking? Anything below say 11.5v or so may support the idea that the battery is on the way out. BTW, you do pull the clutch lever when cranking a cold bike, yes? I'll check the cold cranking drop in the morning. Should I pull the clutch in on a cold crank? Usually I put in neutral, click up the idle assist and hit the start button. Link to comment
ShovelStrokeEd Posted October 26, 2005 Share Posted October 26, 2005 Pulling in the clutch will disconnect the transmission and thus remove the load of the input and intermediate shafts turning in cold oil. Link to comment
ClearwaterBMW Posted October 26, 2005 Share Posted October 26, 2005 on my R1200GS (should be the same answer at the RT) i have the very accurate garmin voltage meter on my 376C voltage before starting 12.2 will go up to a max of 14.1 volts after it is run for a long time voltage after not being ridden for 2 weeks: 12.1 greg Link to comment
johnlt Posted October 26, 2005 Share Posted October 26, 2005 No matter how good the "meter" is, the length and guage of the wire and quality of the connections can make a big difference if the readings. That means on the Garmin unit (I have a 276C with voltage readout)it is important to have a quality power line and ground for the voltage readings to be accurate. Link to comment
Paul Mihalka Posted October 26, 2005 Share Posted October 26, 2005 No matter how good the "meter" is, the length and guage of the wire and quality of the connections can make a big difference if the readings. That means on the Garmin unit (I have a 276C with voltage readout)it is important to have a quality power line and ground for the voltage readings to be accurate. Correct. 12.1 or 12.2 is way too low for a fully charged battery. It should be between 12.6 and 12.8 volts. Link to comment
ClearwaterBMW Posted October 26, 2005 Share Posted October 26, 2005 i guess i'll have to get some accurate meter and put it directly to the battery.... and another from some aux socket output and compare the 2 now, what meter do you recommend? greg Link to comment
cranezilla Posted October 26, 2005 Share Posted October 26, 2005 Battery Tutorial You have most likely heard the term K.I.S.S. (Keep It Simple, Stupid). I am going to attempt to explain how lead acid batteries work and what they need without burying you with a bunch of needless technical data. Actually I have found that battery manufacturer's data will vary somewhat so I must generalize in some cases. The commercial use of the lead acid battery is over 100 years old. The same chemical principal is being used to create energy that our Great, Great, Grandparents may have used. If you can grasp the basics you will have fewer battery problems and will gain greater battery performance, reliability, and longevity. I suggest you read the entire tutorial, however I have indexed all the information for a quick read and easy reference. A battery is like a piggy bank. If you keep taking out and putting nothing back you soon will have nothing. Present day chassis battery power requirements are huge. Look at today’s vehicle and all the electrical devices that must be supplied. Electronics require a source of reliable power. Poor battery condition can cause expensive electronic component failure. Did you know that the average auto has 11 pounds of wire in the electrical system? Look at RVs and boats with all the electrical gadgets that require power. I can remember when a trailer or motor home had a single 12-volt house battery. Today it is standard to have 2 or more house batteries powering inverters up to 4000 watts. Average battery life has become shorter as energy requirements have increased. Life span depends on usage; 6 months to 48 months, yet only 30% of all batteries actually reach the 48-month mark. A Few Basics The Lead Acid battery is made up of plates, lead, and lead oxide (various other elements are used to change density, hardness, porosity, etc.) with a 35% sulfuric acid and 65% water solution. This solution is called electrolyte which causes a chemical reaction that produce electrons. When you test a battery with a hydrometer you are measuring the amount of sulfuric acid in the electrolyte. If your reading is low, that means the chemistry that makes electrons is lacking. So where did the sulfur go? It is resting to the battery plates and when you recharge the battery the sulfur returns to the electrolyte. Safety Battery types, Deep Cycle and Starting Wet Cell, Gel-Cell and Absorbed Glass Mat (AGM) CCA, CA, AH and RC; what's that all about? Battery Maintenance Battery Testing Selecting and Buying a New Battery Battery Life and Performance Battery Charging Battery Do's Battery Don'ts 1. We must think safety when we are working around and with batteries. Remove all jewelry. After all you don't want to melt your watchband while you are wearing the watch. The hydrogen gas that batteries make when charging is very explosive. I have had 2 batteries blow up and drench me in sulfuric acid. That is no fun. This is a good time to use those safety goggles that are hanging on the wall. Sulfuric Acid eats up clothing and you may want to select Polyester clothing to wear, as it is naturally acid resistant. I just wear junk clothes, after all Polyester is so out of style. When doing electrical work on vehicles it is best to disconnect the ground cable. Just remember you are messing with corrosive acid, explosive gases and 100's amps of electrical current. 2. Basically there are two types of batteries; starting (cranking), and deep cycle (marine/golf cart). The starting battery (SLI starting lights ignition) is designed to deliver quick bursts of energy (such as starting engines) and have a greater plate count. The plates will also be thinner and have somewhat different material composition. The deep cycle battery has less instant energy but greater long-term energy delivery. Deep cycle batteries have thicker plates and can survive a number of discharge cycles. Starting batteries should not be used for deep cycle applications. The so-called Dual Purpose Battery is only a compromise between the 2 types of batteries. 3. Wet Cell (flooded), Gel Cell, and Absorbed Glass Mat (AGM) are various versions of the lead acid battery. The wet cell comes in 2 styles; serviceable, and maintenance free. Both are filled with electrolyte and I prefer one that I can add water to and check the specific gravity of the electrolyte with a hydrometer. The Gel Cell and the AGM batteries are specialty batteries that typically cost twice as much as a premium wet cell. However they store very well and do not tend to sulfate or degrade as easily or as easily as wet cell. There is little chance of a hydrogen gas explosion or corrosion when using these batteries; these are the safest lead acid batteries you can use. Gel Cell and some AGM batteries may require a special charging rate. I personally feel that careful consideration should be given to the AGM battery technology for applications such as Marine, RV, Solar, Audio, Power Sports and Stand-By Power just to name a few. If you don't use or operate your equipment daily; this can lead premature battery failure; or depend on top-notch battery performance then spend the extra money. Gel Cell batteries still are being sold but the AGM batteries are replacing them in most applications. There is a little confusion about AGM batteries because different manufactures call them different names; some of the popular ones are sealed regulated valve, dry cell, non-spillable, and sealed lead acid batteries. In most cases AGM batteries will give greater life span and greater cycle life than a wet cell battery. SPECIAL NOTE about Gel Batteries: It is very common for individuals to use the term GEL CELL when referring to sealed, maintenance free batteries, much like one would use Kleenex when referring to facial tissue or "Xerox machine" when referring to a copy machine. Be very careful when specifying a battery charger, many times we are told by customer they are requiring a charger for a Gel Cell battery and in fact the battery is not a Gel Cell. AGM: The Absorbed Glass Matt construction allows the electrolyte to be suspended in close proximity with the plateÕs active material. In theory, this enhances both the discharge and recharge efficiency. Actually, the AGM batteries are a variant of Sealed VRLA batteries. Popular usage high performance engine starting, power sports, deep cycle, solar and storage battery. The AGM batteries we sell are typically good deep cycle batteries and they deliver best life performance if recharged before the battery drops below the 50 percent discharge rate. If these AGM batteries are discharged to a rate of 100 percent the cycle life will be 300 plus cycles and this is true of most AGM batteries rated as deep cycle batteries. GEL: The gel cell is similar to the AGM style because the electrolyte is suspended, but different because technically the AGM battery is still considered to be a wet cell. The electrolyte in a GEL cell has a silica additive that causes it to set up or stiffen. The recharge voltages on this type of cell are lower than the other styles of lead acid battery. This is probably the most sensitive cell in terms of adverse reactions to over-voltage charging. Gel Batteries are best used in VERY DEEP cycle application and may last a bit longer in hot weather applications. If the incorrect battery charger is used on a Gel Cell battery poor performance and premature failure is certain. 4. CCA, CA, AH and RC what are these all about? Well these are the standards that most battery companies use to rate the output and capacity of a battery. Cold cranking amps (CCA) is a measurement of the number of amps a battery can deliver at 0 ° F for 30 seconds and not drop below 7.2 volts. So a high CCA battery rating is good especially in cold weather. CA is cranking amps measured at 32 degrees F. This rating is also called marine cranking amps (MCA). Hot cranking amps (HCA) is seldom used any longer but is measured at 80 ° F. Reserve Capacity (RC) is a very important rating. This is the number of minutes a fully charged battery at 80 ° F will discharge 25 amps until the battery drops below 10.5 volts. An amp hour (AH) is a rating usually found on deep cycle batteries. If a battery is rated at 100 amp hours it should deliver 5 amps for 20 hours, 20 amps for 5 hours, etc. 5. Battery Maintenance is an important issue. The battery should be cleaned using a baking soda and water mix; a couple of table spoons to a pint of water. Cable connection needs to be clean and tightened. Many battery problems are caused by dirty and loose connections. A serviceable battery needs to have the fluid level checked. Use only mineral free water. Distilled water is best. Don't overfill battery cells especially in warmer weather. The natural fluid expansion in hot weather will push excess electrolytes from the battery. To prevent corrosion of cables on top post batteries use a small bead of silicon sealer at the base of the post and place a felt battery washer over it. Coat the washer with high temperature grease or petroleum jelly (Vaseline), then place cable on the post and tighten. Coat the exposed cable end with the grease. Most folks don't know that just the gases from the battery condensing on metal parts cause most corrosion. 6. Battery Testing can be done in more than one way. The most popular is measurement of specific gravity and battery voltage. To measure specific gravity buy a temperature compensating hydrometer and measure voltage, use a digital D.C. Voltmeter. A good digital load tester may be a good purchase if you need to test batteries sealed batteries. You must first have the battery fully charged. The surface charge must be removed before testing. If the battery has been sitting at least several hours (I prefer at least 12 hours) you may begin testing. To remove surface charge the battery must experience a load of 20 amps for 3 plus minutes. Turning on the headlights (high beam) will do the trick. After turning off the lights you are ready to test the battery. State of Charge Specific Gravity Voltage 12V 6V 100% 1.265 12.7 6.3 *75% 1.225 12.4 6.2 50% 1.190 12.2 6.1 25% 1.155 12.0 6.0 Discharged 1.120 11.9 6.0 *Sulfation of Batteries starts when specific gravity falls below 1.225 or voltage measures less than 12.4 (12v Battery) or 6.2 (6 volt battery). Sulfation hardens the battery plates reducing and eventually destroying the ability of the battery to generate Volts and Amps. Load testing is yet another way of testing a battery. Load test removes amps from a battery much like starting an engine would. A load tester can be purchased at most auto parts stores. Some battery companies label their battery with the amp load for testing. This number is usually 1/2 of the CCA rating. For instance, a 500CCA battery would load test at 250 amps for 15 seconds. A load test can only be performed if the battery is near or at full charge. The results of your testing should be as follows: Hydrometer readings should not vary more than .05 differences between cells. Digital Voltmeters should read as the voltage is shown in this document. The sealed AGM and Gel-Cell battery voltage (full charged) will be slightly higher in the 12.8 to 12.9 ranges. If you have voltage readings in the 10.5 volts range on a charged battery, that indicates a shorted cell. If you have a maintenance free wet cell, the only ways to test are voltmeter and load test. Most of the maintenance free batteries have a built in hydrometer that tells you the condition of 1 cell of 6. You may get a good reading from 1 cell but have a problem with other cells in the battery. When in doubt about battery testing, call the battery manufacturer. Many batteries sold today have a toll free number to call for help. 7. Selecting a Battery - When buying a new battery I suggest you purchase a battery with the greatest reserve capacity or amp hour rating possible. Of course the physical size, cable hook up, and terminal type must be a consideration. You may want to consider a Gel Cell or an Absorbed Glass Mat (AGM) rather than a Wet Cell if the application is in a harsher environment or the battery is not going to receive regular maintenance and charging. Be sure to purchase the correct type of battery for the job it must do. Remember an engine starting battery and deep cycle batteries are different. Freshness of a new battery is very important. The longer a battery sits and is not re-charged the more damaging sulfation build up there may be on the plates. Most batteries have a date of manufacture code on them. The month is indicated by a letter 'A' being January and a number '4' being 2004. C4 would tell us the battery was manufactured in March 2004. Remember the fresher the better. The letter "i" is not used because it can be confused with #1. Battery warranties are figured in the favor of battery manufactures. Let's say you buy a 60-month warranty battery and it lives 41 months. The warranty is pro-rated so when taking the months used against the full retail price of the battery you end up paying about the same money as if you purchased the battery at the sale price. This makes the manufacturer happy. What makes me happy is to exceed the warranty. Let me assure you it can be done. 8. Battery life and performance - Average battery life has become shorter as energy requirements have increased. Two phrases I hear most often are "my battery won't take a charge, and my battery won't hold a charge". Only 30% of batteries sold today reach the 48-month mark. In fact 80% of all battery failure is related to sulfation build-up. This build up occurs when the sulfur molecules in the electrolyte (battery acid) become so deeply discharged that they begin to coat the battery's lead plates. Before long the plates become so coated that the battery dies. The causes of sulfation are numerous. Let me list some for you. Batteries sit too long between charges. As little as 24 hours in hot weather and several days in cooler weather. Battery is stored without some type of energy input. "Deep cycling" an engine starting battery. Remember these batteries can't stand deep discharge. Undercharging of a battery, to charge a battery (letÕs say) to 90% of capacity will allow sulfation of the battery using the 10% of battery chemistry not reactivated by the incomplete charging cycle. Heat of 100 plus F., increases internal discharge. As temperatures increase so does internal discharge. A new fully charged battery left sitting 24 hours a day at 110 degrees F for 30 days would most likely not start an engine. Low electrolyte level - battery plates exposed to air will immediately sulfate. Incorrect charging levels and settings. Most cheap battery chargers can do more harm than good. See the section on battery charging. Cold weather is also hard on the battery. The chemistry does not make the same amount of energy as a warm battery. A deeply discharged battery can freeze solid in sub zero weather. Parasitic drain is a load put on a battery with the key off. More info on parasitic drain will follow in this document. There are ways to greatly increase battery life and performance. All the products we sell are targeted to improve performance and battery life. An example: Let's say you have "toys"; an ATV, classic car, antique car, boat, Harley, etc. You most likely don't use these toys 365 days a year as you do your car. Many of these toys are seasonal so they are stored. What happens to the batteries? Most batteries that supply energy to power our toys only last 2 seasons. You must keep these batteries from sulfating or buy new ones. We sell products to prevent and reverse sulfation. The PulseTech products are patented electronic devices that reverse and prevent of sulfation. Also Battery Equaliser a chemical battery additive has proven itself very effective in improving battery life and performance. Other devices such as Solar Trickle Chargers are a great option for battery maintenance. Parasitic drain is a load put on a battery with the key off. Most vehicles have clocks, engine management computers, alarm systems, etc. In the case of a boat you may have an automatic bilge pump, radio, GPS, etc. These devices may all be operating without the engine running. You may have parasitic loads caused by a short in the electrical system. If you are always having dead battery problems most likely the parasitic drain is excessive. The constant low or dead battery caused by excessive parasitic energy drain will dramatically shorten battery life. If this is a problem you are having, check out the Priority Start and Marine Priority Start to prevent dead batteries before they happen. This special computer switch will turn off your engine start battery before all the starting energy is drained. This technology will prevent you from deep cycling your starting battery. 9. Battery Charging - Remember you must put back the energy you use immediately. If you don't the battery sulfates and that affects performance and longevity. The alternator is a battery charger. It works well if the battery is not deeply discharged. The alternator tends to overcharge batteries that are very low and the overcharge can damage batteries. In fact an engine starting battery on average has only about 10 deep cycles available when recharged by an alternator. Batteries like to be charged in a certain way, especially when they have been deeply discharged. This type of charging is called 3 step regulated charging. Please note that only special SMART CHARGERS using computer technology can perform 3 step charging techniques. You don't find these types of chargers in parts stores and Wal-Marts. The first step is bulk charging where up to 80% of the battery energy capacity is replaced by the charger at the maximum voltage and current amp rating of the charger. When the battery voltage reaches 14.4 volts this begins the absorption charge step. This is where the voltage is held at a constant 14.4 volts and the current (amps) declines until the battery is 98% charged. Next comes the Float Step. This is a regulated voltage of not more than 13.4 volts and usually less than 1 amp of current. This in time will bring the battery to 100% charged or close to it. The float charge will not boil or heat batteries but will maintain the batteries at 100% readiness and prevent cycling during long term inactivity. Some gel cell and AGM batteries may require special settings or chargers. 10. Battery Do's Think Safety First. Do read entire tutorial Do regular inspection and maintenance especially in hot weather. Do recharge batteries immediately after discharge. Do buy the highest RC reserve capacity or AH amp hour battery that will fit your configuration. 11. Battery Don'ts Don't forget safety first. Don't add new electrolyte (acid). Don't use unregulated high output battery chargers to charge batteries. Don't place your equipment and toys into storage without some type of device to keep the battery charged. Don't disconnect battery cables while the engine is running (your battery acts as a filter). Don't put off recharging batteries. Don't add tap water as it may contain minerals that will contaminate the electrolyte. Don't discharge a battery any deeper than you possibly have to. Don't let a battery get hot to the touch and boil violently when charging. Don't mix size and types of batteries. There are many points and details I have not written about but I wanted to keep this as short and simple as possible. Further information can be found at the links below. If you are aware of sites with good battery maintenance information please let me know. Additional Battery Tutorial http://www.batteryfaq.org Link to comment
AZJerry Posted October 26, 2005 Share Posted October 26, 2005 Lead acid batteries can last 20 years with the proper care. Your local telephone company will replace their batteries at about 18 years. Lucent (AT&T) Round Cells were rated at 25 years when they first came out. The phone companies keep their bateries at about 70 degrees, on float charge, use only distilled water and preform preventative maintenance i.e. check water level, call voltage, specific gravity etc. At one time I was given a percent of battery life that was lost for every degree of increased average temperature of the battery. That was long ago when to replace a battery string, 24 cells, the string cost about $800 per cell. On top of this there was the cost of installation and miscellaneous hardware. This is why phone companies treated their batteries well and your phone always worked when the power went off. The larger cells we used were called submarine batteries becaused they were like the ones user in submarines. They contained about 30 gallons of acid. Link to comment
ClearwaterBMW Posted October 26, 2005 Share Posted October 26, 2005 wow that is quite interesting, and not completely new to me.... though i have forgotten most of that from days in chemistry class at the University of Miami... i appreciate that extensive information i shall read it more than once i always love to learn..... thanks greg Link to comment
madness522 Posted October 26, 2005 Author Share Posted October 26, 2005 Dude, that is way more than I bargained for!! Thanks for the great info. Think I'll book mark this one for future reference. Link to comment
bmwmick Posted October 26, 2005 Share Posted October 26, 2005 Virgil, GREAT tutorial on batteries and the ways we use/abuse them. One thing you kinda twisted is the fact that HEAT is much harder on batteries than cold. Here is your reference: http://www.uuhome.de/william.darden/carfaq12.htm Here in the southwest, if we get 3 years out of a normal battery, we're doing pretty good. Interstate had a model that fit my wife's Z3 that had a 5 year full replacement warranty. The first one lasted 4 years 6 months, the second one was replaced at 3 years 1 month and Interstate discontinued that model of battery (wonder why?) I use Panasonic AGM/VRLA batteries in all three bikes and just replace them about every 3 Years. I've only had one fail "in service" in the last 10 years. Thanks, Mick Link to comment
Rinkydink Posted October 27, 2005 Share Posted October 27, 2005 Great post, I work in the central office for a major telecommunications firm and you hit the nail on the head. We coddle the batteries where I work and they are long-lasting. Of course, without power everything stops. Link to comment
Reddog900 Posted October 27, 2005 Share Posted October 27, 2005 Great Post!! Thanks for sharing. Makes me want to go out and buy a hydrometer. A Question concerning adding water - does bottled water have all the bad stuff/minerals in it or is it safe to use like distilled? This is the regular water, not sweetened or flavored? Link to comment
ShovelStrokeEd Posted October 27, 2005 Share Posted October 27, 2005 Bottled water is not at all the same is distilled. In fact, before Pepsi (Dasani) and others started bottling tap water most folks called it mineral water. You might have to go to a pharmacy to get real distilled water by now. Link to comment
Global_Rider Posted October 27, 2005 Share Posted October 27, 2005 Barry and others... Download the YUASA Technical Manual. It has all the answers without going into unnecessary battery theory. If you want more theoretical info, then go to the Battery University. Quality batteries last a very long time with simple care and maintenance. I get close to 10 years out of my motorcycle batteries and the factory original in the car is just over 15 years old and not even showing signs of slowing down. Link to comment
