JoeR Posted September 27, 2010 Share Posted September 27, 2010 The last few times I've cranked my bike, my ABS lights have started to blink in an alternating pattern and don't go out when I drive off. It may be a coincidence, but it also seems to be a longer crank when this happens. When this happens, I come to a stop. I let the motor warm up a little then turn off the key. When I turn the key back on and crank it, it fires right up and the ABS lights go out as expected when I take off. I read somewhere that low voltage will cause the ABS failure. Is this the beginning signs of a bad battery? Should I try a replacement battery? I leave the battery on a tender 24-7 when not riding. I ride the motorcycle daily. Link to comment
JonathanE Posted September 27, 2010 Share Posted September 27, 2010 Hi Joe, I would recommend skipping the Battery Tender if you ride daily. Using a Tender when the battery is fully charged just (slowly) boils acid. Have you checked your cell levels lately? If they are low, a little distilled water may solve your problem. If not, or if it's a sealed battery (gel or AGM), then you probably need a new battery. Good luck! Link to comment
JoeR Posted September 27, 2010 Author Share Posted September 27, 2010 Thanks for the replies; I'm pretty sure it's a sealed battery (I inherited it from the PO, so I'm not sure), but this has me on the right track. This does bring up one question; I bought a "smart" battery tender. I thought they were supposed to turn off when the battery is charged. The light does turn to green pretty quickly, which I thought meant it has stopped charging. Is this not the case? Link to comment
boatzo Posted September 27, 2010 Share Posted September 27, 2010 Hi Joe, you are correct about the light on the smart tender. Sounds like your battery is getting a charge but not holding. The only way to tell if the battery is OK is to get it load tested. They can do that at a battery shop and it will tell you the condition. I can tell you from personal experience, that the start load can pull down a marginal battery quickly and that WILL make the ABS lights alternate. I changed out my gel battery for an AGM and have not had the flashing lights since. BTW, that battery is still working fine 3 years later on my generator. The generator doesn't have ABS Link to comment
