mikecrml Posted September 24, 2010 Share Posted September 24, 2010 I have a 2004 RTP with 63,000 miles. Latley the idle seems rough, but runs fine at all speeds.. The bike has been completly serviced.TB sync, valve adjust, fliuds and fuel filter. I suspect the HES sensor. Do they die slow, painful deaths or quit altogether? Any advise? Link to comment
dirtrider Posted September 24, 2010 Share Posted September 24, 2010 Hi mikecrml Being as you have a 2004 the HES would be way way down the list of possibilities on a rough idle. The 1150 series have very few HES problems and seldom would you find an HES failure to be only a rough idle but run good at other RPM ranges. Maybe start with a good hot compression test, then make sure your stick coils are operating properly. Look for excessively worn throttle shafts or shaft bores. Look for fully functional BBS screws with no plugged passages under the BBS screws. Maybe try unplugging the o2 sensor to see if that is causing the problem. Link to comment
dan cata Posted September 24, 2010 Share Posted September 24, 2010 I have changed some HES plates now, on both 1100 and 1150! In all cases, the wiring was bad; I believe it has to do with owners heating the engines while standing... Link to comment
AndyS Posted September 24, 2010 Share Posted September 24, 2010 I'm with Dirtrider on this. |I doubt very much if your HES has anything to do with it. Have you replaced your plugs at the service? Have you tried swapping the stick coils out with one of your buddies? When serviced, have they actually cleaned the Throttle bodies. The BBS may need removing and cleaning (along with the TB's). Have you checked for air leaks. Andy Link to comment
NonComp Posted September 24, 2010 Share Posted September 24, 2010 I have changed some HES plates now, on both 1100 and 1150! In all cases, the wiring was bad; I believe it has to do with owners heating the engines while standing... In the real world, people ride on hot days and get caught in traffic jams. IMO, only boxers that spend their life sitting in people's garages will have undeteriorated HES wire insulation. Link to comment
dan cata Posted September 24, 2010 Share Posted September 24, 2010 Plenty of jams over here, but I ride between car rows, until the day will come and someone may open a car door in front of me Until then... I have never got my bikes over 6 bars. The RT once got to 6. Link to comment
redryder Posted September 27, 2010 Share Posted September 27, 2010 I have a 2004 RTP with 63,000 miles. Latley the idle seems rough, but runs fine at all speeds.. The bike has been completly serviced.TB sync, valve adjust, fliuds and fuel filter. I suspect the HES sensor. Do they die slow, painful deaths or quit altogether? Any advise? Did you do the service work yourself? Sounds to me more like it's in need of a very accurate valve adjust followed by a meticulous TBS sync. When the HES on mine quit, it just quit without warning. It was a rainy day and fortunately it was in the hotel parking lot and not a few minutes later on the ATL freeway. Also, it could be the coils, but they usually will give trouble when hot and run ok when cool. In all my experience, a rough running oilhead is in need of a very good tune up. Link to comment
carolinarider Posted September 28, 2010 Share Posted September 28, 2010 When my HES failed last winter, I was on my way home from work in the rain..the bike just died immediately. Sounds like yours needs a good accurate tune up...Good luck ! Link to comment
topdal46 Posted September 28, 2010 Share Posted September 28, 2010 When my HES, died, it did it suddenly,,10 miles south of the rally site in Lima,Ohio,, when was that 2005?? Link to comment
