mrfbuyer7 Posted September 20, 2010 Share Posted September 20, 2010 So how do I know if my 1995 R1100R has ABS (without testing it). I have no paper work on the bike, I am sure there is an easy way to tell? Thanks Link to comment
NonComp Posted September 20, 2010 Share Posted September 20, 2010 It will have a pair of ABS lights on the right side of your instrument cluster that flash every time yout start the bike up. It will also have exposed gear-like rings on the front and rear wheels that have sensors near them, that monitor wheel revs. It will also make a peculiar click/whirr/clank sound every time you start to pull away from a cold startup. Link to comment
mrfbuyer7 Posted September 20, 2010 Author Share Posted September 20, 2010 NonComp, Thanks so much for the information! Link to comment
NonComp Posted September 20, 2010 Share Posted September 20, 2010 No problem. I have a '96 r1100r that is probably quite similar to your '95. Link to comment
tallman Posted September 20, 2010 Share Posted September 20, 2010 That's ABS II era, ind. F/R. Decals. ABS ring. Didn't think that had power assist. Link to comment
NonComp Posted September 20, 2010 Share Posted September 20, 2010 No power assist (thank heaven). No decals on mine, but then I think ABS was standard on models sold outside of the Con US. Link to comment
tallman Posted September 20, 2010 Share Posted September 20, 2010 I think the '99's, starting w/production in November of '98 is where the ABS became an option. Link to comment
