Robt_J_Webster Posted August 19, 2010 Share Posted August 19, 2010 I ran across a reference to a terminal for jump-starting an R1150RT on the Motoworks website (see below) Jumper Terminal The Motoworks website states that this is on all machines after late 2003. Does anyone know if this is correct? If so, where is this terminal post located? If not, has anyone installed one of these kits? Looks like a good idea. Thanks in advance for any information. Link to comment
Boffin Posted August 19, 2010 Share Posted August 19, 2010 On the RT the post is under the riders seat at the front. It is covered by a black plastic cap. On other models, it is on the starter motor cover, by the LH riders footpag. My R1150RT came from the factory witht the post and I have also fitted one to a friends 2002 RT. Andy Link to comment
Robt_J_Webster Posted August 19, 2010 Author Share Posted August 19, 2010 Thanks for the feedback. I am not near my bike at the moment, and was contemplating ordering one of these kits. Do you know if a European 2004 RT would have come with this installed? Link to comment
Boffin Posted August 19, 2010 Share Posted August 19, 2010 Mine did - I live in England. Andy Link to comment
AndyS Posted August 19, 2010 Share Posted August 19, 2010 Thanks for the feedback. I am not near my bike at the moment, and was contemplating ordering one of these kits. Do you know if a European 2004 RT would have come with this installed? Yep, mine has one too. Remember of course it can be fitted to earlier model years too. Andy Link to comment
Mr. Frank Posted August 19, 2010 Share Posted August 19, 2010 In the States the jump start terminal extension began to appear on late model 2004 R1150RT models. It attaches to the + terminal. It involves about three parts and can be added to earlier models. Link to comment
realshelby Posted August 19, 2010 Share Posted August 19, 2010 The Motoworks website states that this is on all machines after late 2003. Does anyone know if this is correct? I suspect the 2003 listed above is build date. My '04 RT did not have one. But its build date is 12/2002. So possibly only the very late '04 models or possibly '05 models would have this? At any rate it is a good thing to have. I build one that I can reach by taking my seat off. Had a less than 1 year old battery fail when I tried to come home from work. If I had not had help pushing it, I would never have gotten it bump-started! Link to comment
Stonecritter Posted August 19, 2010 Share Posted August 19, 2010 In the States the jump start terminal extension began to appear on late model 2004 R1150RT models. It attaches to the + terminal. It involves about three parts and can be added to earlier models. My US BMW dealer has no information on this kit. Does anyone know where one could be found or instructions on how you built your own? Dave Link to comment
Boffin Posted August 19, 2010 Share Posted August 19, 2010 In the States the jump start terminal extension began to appear on late model 2004 R1150RT models. It attaches to the + terminal. It involves about three parts and can be added to earlier models. My US BMW dealer has no information on this kit. Does anyone know where one could be found or instructions on how you built your own? Dave The parts are standard BMW pieces fitted to the later RT - from late 2004 in the USA. They are parts 9-11 on this diagram: Link to realoem.com Andy Link to comment
AndyS Posted August 19, 2010 Share Posted August 19, 2010 Hi Dave, these parts are standard items as listed below. Andy beat me to it again! Andy Link to comment
Shuffler Posted August 19, 2010 Share Posted August 19, 2010 The accessory plug on my 1100RT is hot. Is there any reason why you couldn't use jumper cables on one end, and a Powerlet socket on the other, to plug into the accessory socket and jump start your bike from another's battery? Just thinking off the top of my head here... Link to comment
Boffin Posted August 19, 2010 Share Posted August 19, 2010 The accessory plug on my 1100RT is hot. Is there any reason why you couldn't use jumper cables on one end, and a Powerlet socket on the other, to plug into the accessory socket and jump start your bike from another's battery? Just thinking off the top of my head here... The accessory socket is good for about 10-15 amps. Jump-starting pulls 50-100 amps. The wires would burn out, possibly starting a fire.. What does work, is to use the socket to charge your battery off the other bike. Leave it connected for 10-15 minutes, then disconnect and try to start the bike. Do not do try to start the bike with the lead connected. In fact, when jump-starting any vehicle, connect the jump leads and let the donor vehicle charge the dead battery for 5-10 minutes before starting the dead vehicle - it lets all of the donor vehicles current go to starting the vehicle, rather than just being soaked up by the battery. Andy Link to comment
Stonecritter Posted August 19, 2010 Share Posted August 19, 2010 That's a help. Any pictures of how this looks installed? I'll check back with my dealer when the good parts guy is back from vacation. Anyone have any experience with the Bikestart Connector available from Wunderlich? http://www.wunderlichamerica.com/motorcycle/2024567.html Link to comment
Unhofliche_Gesundheit Posted August 19, 2010 Share Posted August 19, 2010 good cheap option that i read about here. make your own + batt extension. some cable and a crimped on ring terminal attached to the batt. leave it hidden under the seat. 6" long should do it. 8 awg maybe? i would go with something as finely stranded as possible. cover the loose end of the extension with heat shrink. cant cost more that a few bucks and no waiting or shipping. no worries with battery terminal geometry and size not working with the bwm battery extensio parts. for example i have a pc680 with top connection. does not resemble the battery in the picture above. i could see the bmw parts not working... Link to comment
Slyder_Steve Posted August 19, 2010 Share Posted August 19, 2010 Super easy install. My 04 did not come with it, but I installed it a few years ago. I had to take the battery out, (to get to the positive terminal) aside from that it's no harder than removing the terminal lead. Steve Link to comment
moshe_levy Posted August 20, 2010 Share Posted August 20, 2010 My '04 RT (early build date) did not have one. I installed one and also made an "accessory stud" on it for easier access - very crude compared to the Centech on my '09! Here it is Takes very little effort to install and WILL come in handy if you need a jump. -MKL Link to comment
Stonecritter Posted August 20, 2010 Share Posted August 20, 2010 My '04 RT (early build date) did not have one. I installed one and also made an "accessory stud" on it for easier access - very crude compared to the Centech on my '09! Here it is Takes very little effort to install and WILL come in handy if you need a jump. -MKL That makes it more clear. Accessory stud a nice idea too. I used the +/- on my Centech to get jump start after customs in Buffalo on Sunday. From other parts of this discussion, sounds like I was lucky. Link to comment
moshe_levy Posted August 20, 2010 Share Posted August 20, 2010 Yeah, I had to do the stud. I had tons of accessories all on the + terminal on my '04 - with the jump post, it would have been ridiculous to try to access them easily. A fuse block however is far preferred. -MKL Link to comment
Stonecritter Posted August 20, 2010 Share Posted August 20, 2010 Yeah, I had to do the stud. I had tons of accessories all on the + terminal on my '04 - with the jump post, it would have been ridiculous to try to access them easily. A fuse block however is far preferred. -MKL Been there done that. Roadstar a couple bikes back ended up with severe problems as a result of stack of wires loosening up on the + terminal. Added simple fuse block on that bike and a Centech on the RT behind left side panel. I used the +/- there for a jump. Link to comment
Rocer Posted August 21, 2010 Share Posted August 21, 2010 And here's another clever possibility posted on another board: http://img831.imageshack.us/img831/6223/jumpers.jpg Link to comment
DrPaul Posted August 22, 2010 Share Posted August 22, 2010 Just pick up a short (12-18") battery cable for a lawn tractor/mower. Attach to the + post and slide a piece of snug fitting rubber hose over the other end. Let it lay atop the right frame rail. Link to comment
Perlova Posted August 5, 2011 Share Posted August 5, 2011 Hi Dave, these parts are standard items as listed below. Andy beat me to it again! Andy What exactly is part 13 for? Is that a battery holder? Link to comment
