Pickaxe Posted October 20, 2005 Share Posted October 20, 2005 Sorry if this has been covered, but couldn't find it with a search. Can someone tell me where the GPS electrical socket is, on the 12RT. Link to comment
decorbin Posted October 21, 2005 Share Posted October 21, 2005 It is right under the support that goes to the front fairing and headlight. It has a cap on it and is zip tied to the support. I'm in a hotel running from the hurricane or would take a picture and show it. I know there was a picture on this site some time in the last few months, so try using the search function and you should find it. You can also ask your dealer. Link to comment
Kiku Posted October 22, 2005 Share Posted October 22, 2005 Here's the pic. I bought Garmin Street Pilot simply for the price. I think BMW navigator II is a rip off. Link to comment
Pickaxe Posted October 22, 2005 Author Share Posted October 22, 2005 thanks both. That's my little job for Monday night, fitting the GPS. Link to comment
bmwscoot Posted October 22, 2005 Share Posted October 22, 2005 A little info. please.... Is there wiring info. available anywhere for the R12RT? In particular the pin outs for this GPS connector? Also, any part # for the mating plug and pins to this connector? Maybe the CD manual for the R12RT has wiring diagrams? Thanks for any information. Link to comment
Kiku Posted October 22, 2005 Share Posted October 22, 2005 I used GARMIN supplied cable; meaning you need to cut the cable for both ends to attach connectors of your own. I used one of those criping terminals. (Please see the attached picture, this is the connector I chopped off from the bike.) There're 3 wires comming out of the bike side coupler. 1. RED - Accessory 12V 2. Brown - GND 3. Blue - Not sure since GPS should work with or without. There're 3 wires from Garmin side, so I connected to a blue one anyway. If you're using NavigatorII, part# for cable you need is 71607686670. For Navigator I, part# is 71607687693. They should give you sweet "Plug and Play" install. For the repair CD manual, part.# is 01797695182. I'm pretty sure wiring/connector are the same, but please note that I own a non-US spec bike. Perhaps you should consult your friendly dealr before ordering. Link to comment
ChrisE Posted October 23, 2005 Share Posted October 23, 2005 You can get this cable also scroll all the way to the bottom of this page. Powerlet.net Link to comment
bmwscoot Posted October 23, 2005 Share Posted October 23, 2005 Thanks for the info guys. I have the mounts and cables for my 2610 install. I was really just wondering if there is a mating connector to the one on the bike already? I was thinking I could just find the correct connector, fit it to my existing 2610 cable, then plug it into the bike plug. Kiku, does the plug you cut off the bike have any mfg. name and/or i.d. numbers on it? I have to do some looking for the connector "plug" me thinks. Thanks again. A new RT is looking pretty probable...just have to get my a** in gear, and spend some money! Link to comment
Kiku Posted October 23, 2005 Share Posted October 23, 2005 Hi Jeff, Yep. There're a few markings on the plug as listed below, but absolutely no idaea what they represent(except for "BMW" of course). Hope this helps and good luck! 1. On the black outer part of the plug >PBT-GF10< 1452049-1 A 2. On the gray inner part of the plug 965-329-1 :tyco 2-1452050-1 (could be ":tvoo" or ":tyoo" sooooo tiny printing) 3. On the cover BMW 8 367 135 >PBT-GF20< Link to comment
George Posted October 23, 2005 Share Posted October 23, 2005 Pickaxe, just to let you know that the power socket for the GPS goes dead after 1 minute after you have removed the ignition key. Just for your information, can be annoying when fuelling up the bike, popping the seat etc Link to comment
Pickaxe Posted October 23, 2005 Author Share Posted October 23, 2005 Pickaxe, just to let you know that the power socket for the GPS goes dead after 1 minute after you have removed the ignition key. Just for your information, can be annoying when fuelling up the bike, popping the seat etc Thanks for that George, however, I prefer that to having it straight from the battery. Link to comment
bmwscoot Posted October 23, 2005 Share Posted October 23, 2005 Kiku, Thanks for the numbers... I will see what I can do with them! Link to comment
rideLD Posted October 23, 2005 Share Posted October 23, 2005 Not sure about the RT but the R1200GS has a deticated GPS power socket that is plug and play with the Nav2. It is always live and does not go off with the key. The Nav2 cable plugs into it under the tank. I think the power sorce with the strange connector that you guys are talking about is for an optional extra accessory socket? I could be wrong, but if BMW provided this handy GPS power supply for the GS, they surely did on the RT. An easy way to check would be to ask someone who ordered an RT with a Nav2 installed if their Nav2 will stay on with the key off. If so there is another power sorce that you have not found yet. Link to comment
Pickaxe Posted October 23, 2005 Author Share Posted October 23, 2005 Not sure about the RT but the R1200GS has a deticated GPS power socket that is plug and play with the Nav2. It is always live and does not go off with the key. The Nav2 cable plugs into it under the tank. I think the power sorce with the strange connector that you guys are talking about is for an optional extra accessory socket? I could be wrong, but if BMW provided this handy GPS power supply for the GS, they surely did on the RT. An easy way to check would be to ask someone who ordered an RT with a Nav2 installed if their Nav2 will stay on with the key off. If so there is another power sorce that you have not found yet. My present bike (until tomorrow) is a 12GS. I'm aware of the dedicated plug on that, and it does turn off with the ignition(remains live for about a minute after the ignition is turned off). I wonder if the third terminal maybe a dedicated/inteligent link for the BMW/Garmin unit? Link to comment
92232 Posted October 23, 2005 Share Posted October 23, 2005 The plug is made by "TYCO". They own AMP which makes alot of the plugs and connectors on the BMW bikes and cars. Link to comment
rideLD Posted October 24, 2005 Share Posted October 24, 2005 My present bike (until tomorrow) is a 12GS. I'm aware of the dedicated plug on that, and it does turn off with the ignition(remains live for about a minute after the ignition is turned off). I wonder if the third terminal maybe a dedicated/inteligent link for the BMW/Garmin unit? Read my post again. You are talking about the accessory plug power cable that goes off 30 seconds to a minute after the key is turned off. I am talking about the connector under the gas tank that is a deticated GPS power point that has a connector that connects to the NAV2 power cable. It is not a bmw plug. It is always on even if the key is off. Link to comment
Pickaxe Posted October 24, 2005 Author Share Posted October 24, 2005 My present bike (until tomorrow) is a 12GS. I'm aware of the dedicated plug on that, and it does turn off with the ignition(remains live for about a minute after the ignition is turned off). I wonder if the third terminal maybe a dedicated/inteligent link for the BMW/Garmin unit? Read my post again. You are talking about the accessory plug power cable that goes off 30 seconds to a minute after the key is turned off. I am talking about the connector under the gas tank that is a deticated GPS power point that has a connector that connects to the NAV2 power cable. It is not a bmw plug. It is always on even if the key is off. The plug I was refering to is the one that is by the headstock and has three pins. Link to comment
Kbasa Posted October 25, 2005 Share Posted October 25, 2005 My present bike (until tomorrow) is a 12GS. I'm aware of the dedicated plug on that, and it does turn off with the ignition(remains live for about a minute after the ignition is turned off). I wonder if the third terminal maybe a dedicated/inteligent link for the BMW/Garmin unit? Read my post again. You are talking about the accessory plug power cable that goes off 30 seconds to a minute after the key is turned off. I am talking about the connector under the gas tank that is a deticated GPS power point that has a connector that connects to the NAV2 power cable. It is not a bmw plug. It is always on even if the key is off. Really? Do you have a picture of this plug? The wiring kit that came with my NavII had a plug that plugged into the accessory outlet's harness. It shuts down with the bike after a 1 minute delay. If there's an outlet without the autoshutdown, I'd rather use that. Thanks! Link to comment
