Brycesdad Posted October 18, 2005 Share Posted October 18, 2005 Thanks to all of you for your input. tonight I pulled of the tupperware to do a zero-zero adjust and found that the screws for the tps are GONE!! I'll have to pick some up tomorrow. does anyone know the size that they are? Rick Miller Link to comment
russell_bynum Posted October 18, 2005 Share Posted October 18, 2005 ????????? Are we talking about the same thing? The TPS is a black sensor attached to the left throttle body with two screws. Are you saying that those two screws are missing? So there's nothing holding the TPS on? Link to comment
Joe Frickin' Friday Posted October 18, 2005 Share Posted October 18, 2005 Thanks to all of you for your input. tonight I pulled of the tupperware to do a zero-zero adjust and found that the screws for the tps are GONE!! I recall from your other threads we had some confusion about terminology. As Russell notes, the TPS is the small black rectangular item present on the LEFT throttle body only; there is no TPS on the right throttle body. There are two screws that lock the TPS housing in a particular orientation. On each throttle cable pulley, there is a stop screw; I recall from your previous threads that you had fiddled with these. On each throttle body, above/outboard/upstream of the throttle body itself, there is a brass screwhead about 3/8" in diameter; this is the idle air bypass screw. Can you confirm again which screws are missing? Link to comment
Stan Walker Posted October 18, 2005 Share Posted October 18, 2005 So there's nothing holding the TPS on? Well, it might explain the poor running if the TPS is dangling at the end of a cable....... <sigh> who coined the phrase that a picture is worth a 1000 words.... <sigh> Stan Link to comment
Brycesdad Posted October 18, 2005 Author Share Posted October 18, 2005 Yes, The tps screws are missing, not dangling there but in place free to rotate or move Link to comment
Pilgrim Posted October 18, 2005 Share Posted October 18, 2005 Yes, The tps screws are missing, not dangling there but in place free to rotate or move Boy! If only all the service questions were that easy to answer. Pilgrim Link to comment
russell_bynum Posted October 18, 2005 Share Posted October 18, 2005 Yes, The tps screws are missing, not dangling there but in place free to rotate or move Is there any way you could post a picture of this? In the picture below, you're looking at the left throttle body. Directly under the person's right hand, you see the black rectangular doohickey with the electrical connector on the bottom of it. That doohickey is the TPS. There are two screws holding the TPS in place. The one on the trailing edge is visible in this picture because it's got a bit of bright blue paint on it. The other is on the leading edge and is not visible. Are those the screws you're talking about? Link to comment
Brycesdad Posted October 18, 2005 Author Share Posted October 18, 2005 yes that's it, I'll post pics later Link to comment
russell_bynum Posted October 18, 2005 Share Posted October 18, 2005 Holy Toledo. Yeah, you definitely need to resolve that. You'll need to do a 0=0 (including a TB sync) when you're done. Link to comment
Brycesdad Posted October 19, 2005 Author Share Posted October 19, 2005 here is the pic of the missing screws, that would probably explain why performance failed while riding..... Link to comment
Brycesdad Posted October 19, 2005 Author Share Posted October 19, 2005 Here is a little bigger picture Link to comment
ShovelStrokeEd Posted October 19, 2005 Share Posted October 19, 2005 That high tension lead looks like crap as well, right where it crosses over the clamp for the throttle body. Appears to be burnt and cracked. You are certainly gonna need a couple of screws and flat washers. Have to get the dealer to give the PN's details, they are pretty darn small. Then a full zero=zero job for you. Link to comment
Ken H. Posted October 19, 2005 Share Posted October 19, 2005 Well it's not too often a new person comes to this board with a totally new problem / situation, but you get this week's award! I have never seen a TPS loose both screws on its own. Definitely a service _uck up IMHO. You didn't say in your other thread if you bought the bike from a dealer or not, but if so, I'd raise some noise there if it was me. Link to comment
Brycesdad Posted October 20, 2005 Author Share Posted October 20, 2005 I didn't buy it from a dealer, I bought it as a rebuilder. light damage from right side sliding on pavement. I rebuild a couple bikes a year but I thought this one would be a nice one to keep for me. Never had a BMW before Link to comment
