soter Posted June 1, 2010 Share Posted June 1, 2010 Well Hallow from Greece !! before few days i have an accident with my 96'R1100RT . The only damage on my bike is the telelever arm and the ball joint I found an used telelever arm but is from R1150GS do you know if is same sizes so i can use on my bike ? Thanks in advance Link to comment
Anton Largiader Posted June 1, 2010 Share Posted June 1, 2010 I think they are the same. I parted out an R11RT and the arm ended up on an 1150GS Adventure after I did some checking of part numbers. Link to comment
Clive Liddell Posted June 1, 2010 Share Posted June 1, 2010 Its the R model Oilheads that would be different due to the mounting for the steering damper. I looked at this and wondered if BMW couldn't have just "built in" two tapped holes and bolted the bracket in place which would have allowed fitting of a steering damper for those who desired it. Link to comment
AndyS Posted June 1, 2010 Share Posted June 1, 2010 Well Hallow from Greece !! before few days i have an accident with my 96'R1100RT . The only damage on my bike is the telelever arm and the ball joint I found an used telelever arm but is from R1150GS do you know if is same sizes so i can use on my bike ? Thanks in advance I would have thought they would be different to generate different trail and castor angles. However they would probably fit. Anyone elso got any hard proof one way or the other? Andy Link to comment
soter Posted June 1, 2010 Author Share Posted June 1, 2010 the part are for the 96' R1100RT 31422345526 and for the 99' R1150GS 31422345526 and 2000 31422311849 from here Link to comment
AndyS Posted June 1, 2010 Share Posted June 1, 2010 Well, that answers your own question. For the model year you selected they are the same. Andy Link to comment
