ltljohn Posted May 27, 2010 Share Posted May 27, 2010 I am doing the 36K service so I decided to put on the metal QD fittings while I had the tank off. I noticed the clamps on one of them were not stock. As I was taking off the clamps I found some writing..... Link to comment
RodB Posted May 27, 2010 Share Posted May 27, 2010 My take on it is that the hose is not meant to be used as a high pressure injection conduit. Should be just fine for use as a normal fuel line. Link to comment
philbytx Posted May 27, 2010 Share Posted May 27, 2010 FYI - Fuel injection hose for external routing has an SAE 30R9 rating for continuous & pressurized flow use. This is not the same rubber fuel hose as used on carbureted applications. Fuel injection hose for in-tank (immersion) use has an SAE 30R10 rating which contains a special compound called fluoroelastomer (FKM), which resists fuel permeation and retards aging. Link to comment
ltljohn Posted May 27, 2010 Author Share Posted May 27, 2010 I just found it funny that the one little short piece of hose had the disclaimer on it. Link to comment
tobyzusa Posted May 27, 2010 Share Posted May 27, 2010 FYI - Fuel injection hose for external routing has an SAE 30R9 rating for continuous & pressurized flow use. This is not the same rubber fuel hose as used on carbureted applications. Fuel injection hose for in-tank (immersion) use has an SAE 30R10 rating which contains a special compound called fluoroelastomer (FKM), which resists fuel permeation and retards aging. Phil, you almost sound like you know what you are talking about! Link to comment
philbytx Posted May 27, 2010 Share Posted May 27, 2010 Yeah I kinda do don't I. Just like our politicians ! I actually garnered this info when looking for replacement inside tank hoses for the RT. Link to comment
