HappyMan Posted October 5, 2005 Share Posted October 5, 2005 ...or really my night? I have a 96 RT and of course as you all know the head light SUCKS! Without adding driving lights is there a way to improve it? Are there any modifications I've missed for improving the headlight? Feel free to point me to a post I might have missed. I'm about as bright as my headlight when it comes to searching this site! Link to comment
Jerry_75_Guy Posted October 5, 2005 Share Posted October 5, 2005 Without adding driving lights? Not that I can think of, but try a search on driving lights; there's a lot here. I added Pilot brand lights (PIAA knockoffs) for $60 and they work great! Link to comment
Rocketman51 Posted October 5, 2005 Share Posted October 5, 2005 I will tell you that I added a HID system to my R1100RT 1997. It was not cheap, $300 ~~. It has a H-4 bulb replacement that changes position when I switch between high and low beam. It is the light this bike needed to ride safe at night. The mfg is no longer in Business because goverment DOT shut them down. Search for HID kits. I will never go back to stock. Link to comment
russell_bynum Posted October 5, 2005 Share Posted October 5, 2005 The easiest, quickest thing is to replace the stock bulb with a better one like the PIAA 55/60 superwhite. That's better than stock, but not much. The best way to increase your forward lighting without adding driving lights, is to install an HID headlight. Do some searches here and I'm sure you'll find some reviews of HID headlights. Link to comment
ScottB Posted October 5, 2005 Share Posted October 5, 2005 John, the most simple thing to do is to just install a 80/100w lamp. These are available at any auto parts store. The lamp may be labeled as 'For offroad use only'. Some say that it will damage or melt the headlight housing, but many have done it without any problems. I have done it on my last two bikes with no problems. The other thing that is recomended is to install larger gauge wiring from your battery or accesory fuse block and only use the factory wiring to switch a relay in the new wiring. This works because it eliminates the problem of voltage drop in the light gauge factory wiring . You can do a search on this upgrade. I have seen it discussed before. Link to comment
HappyMan Posted October 5, 2005 Author Share Posted October 5, 2005 Sounds like the HID is the way to go. I'll search it out. Thanks! Link to comment
HappyMan Posted October 5, 2005 Author Share Posted October 5, 2005 John, the most simple thing to do is to just install a 80/100w lamp. These are available at any auto parts store. The lamp may be labeled as 'For offroad use only'. Some say that it will damage or melt the headlight housing, but many have done it without any problems. I have done it on my last two bikes with no problems. The other thing that is recomended is to install larger gauge wiring from your battery or accesory fuse block and only use the factory wiring to switch a relay in the new wiring. This works because it eliminates the problem of voltage drop in the light gauge factory wiring . You can do a search on this upgrade. I have seen it discussed before. That sounds worth looking into too. Thank you. Link to comment
FlyingFinn Posted October 5, 2005 Share Posted October 5, 2005 That exactly is the problem with HID conversion kits for H4 bulbs. You need to be able to ratain the high/low beam capability of the one bulb. I didn't know there is(was?) a conversion kit that actually does that. All kits I have found replace the high/low of the H4 with just one HID "filament". Not good. H1 and H7 (in 1150RT) are easy, one bulb, one filament. -- Mikko Link to comment
Ron Jarvis Posted October 5, 2005 Share Posted October 5, 2005 John - I added a Phillips bulb (definitely brighter than stock) purchased from England and, I think, now available in US. Also, added inexpensive teardrop shaped lights under the front fairing and attached to the lower side of the vent area with 3/8" thick piece of aluminum for support (jut under the oil cooler. Got the idea and measurements from this site. I have the dimensions at home and can send you a picture or two this weekend, if you are interested. Let me know. It made a big difference day or night. Ron Link to comment
DavidEBSmith Posted October 5, 2005 Share Posted October 5, 2005 Simplest and most cost-effective: - Get a Philips VisionPlus or Osram SilverStar H4 bulb from www.powerbulbs.com. They honestly (and verifiably) put out more light, at stock wattage, cheaper than PIAAs. - Get a headlight relay kit from Eastern Beaver or wire your own headlight relays. I have participated in a head-to-head test of bikes with and without headlight relays and the relays make a visible improvement. As to the other suggestions - PIAA bulbs are overpriced and short-lived. Higher-wattage bulbs have been known to cause wiring and headlight switch problems (although not so much in Oilheads). HID conversions aren't street legal, they're expensive, they can be complicated to install (how do you feel about working around high voltage?), and, sorry to say, the idea of getting high and low beams out of a single bulb by physically moving it back and forth strikes me as asking for failure. Not to mention that the reflector on the R1100RT isn't designed for HID bulbs, will scatter light all over the place, and probably annoy every oncoming driver with the glare. Your Mileage May Vary. Link to comment
Reddog900 Posted October 5, 2005 Share Posted October 5, 2005 I tend to agree with Dave, I went down to WalMart this past weekend and bought a Sylvannia 9003 Halogen H4 lamp, cost me $10.01 out the door, simple change and the light output is 50% better than stock. I tried out a PIAA superwhite, but for $35.00 I sent it back. This cheapo is the way to go. I will put on some another light system, probably motolights in the future. For the price, $10.00, try the WalMart option first. Happy Ridin' Link to comment
scottfarm2 Posted October 5, 2005 Share Posted October 5, 2005 I'm with David, there's is not a better mod than the silverstar for the money. They were $20 a piece at autozone, but I have noticed you can now get two for $32. You will not believe the difference. I get comments all the time even in full sun daylight--man your headlight is bright--what kind is it. Link to comment
HappyMan Posted October 5, 2005 Author Share Posted October 5, 2005 Thanks everyone. I'm going with the cheap option first. Anythings better than that candle they put in there!! Link to comment
kudzu Posted October 5, 2005 Share Posted October 5, 2005 Anythings better than that candle they put in there!! Naw, it's a BMW spec'd candle. Link to comment
HappyMan Posted October 5, 2005 Author Share Posted October 5, 2005 That just means it's really expensive and five engineers worked on it to get it to be that dim, otherwise someone might have hurt themselves looking into the light. I'm surprised they aren't servo linked to the break light.... Link to comment
SnowDog Posted October 5, 2005 Share Posted October 5, 2005 http://www.ebbo.org/headlamp_relays.php Link to comment
HappyMan Posted October 5, 2005 Author Share Posted October 5, 2005 Wow! That picture says it all. Besides the fact that it looks like a picture of my bike!!! Well, except for the fact that I can see the headlight.... Link to comment
rdsmith3 Posted October 5, 2005 Share Posted October 5, 2005 I did what the other Mr. Smith said on my Roadster, which has a single H4 bulb. I installed a 90/100W Philips bulb. I added the Eastern Beaver relays. Things are much better now. I also added Motolights, but they are not cheap. They are, however, very well made. I have them on all the time, and have had no problems. I use 50W yellow bulbs which fill in areas that the headlight does not get, and also greatly enhance the conspicuity of my bike. Link to comment
Larsen Posted October 5, 2005 Share Posted October 5, 2005 John, After my PIAA PA15680 Bulb-H4 80/80 Platinum Halogen Headlamp Bulb quit late at night I replaced it with a new Sylvania XtraVision 9003 60/55 Watt Headlamp Bulb. Right from the start it was much much brighter than the over rated PIAA and had light fill in on each lane next to the lane I was in. It's a very inexpensive way to go before you add additional running lights. On a dark country road at night the difference was amazing! The 9003 is a direct replacement for the H4. Link to comment
eakins Posted October 5, 2005 Share Posted October 5, 2005 here's how to fix> this bulb: http://www.tpi4x4.com/KLR650/Electric.html $35 ipfs are the real deal. see what best rest says about em: http://www.bestrestproducts.com/celestia/products/lighting/ then add this wiring relay (to get full power to the bulb): http://www.easternbeaver.com/Home/Main/Products/H4_kits/h4_kits.html use 2nd one fairing mount. $52 results are amazing by them self. need more light?: http://www.electricalconnection.com/driving-lights/dl_r1100rt.htm go for the supper white. this is a complete kit with lights, mounting brackets, wiring/relays, switches for $145. best deal out there. here's the parts shown: http://www.electricalconnection.com/driving-lights/dl_performance.htm Link to comment
eakins Posted October 5, 2005 Share Posted October 5, 2005 without going overwattage i've tried piaa, philips (from england) & osram/sylvania (from england) and the ipf are better than all. the piaa are over priced. the philips & osrams are better than stock but not as good as the ipf. 80 watts (enhanced with fancy gases for more) is amazing on low beam (where the 1100rt light spreads light well). look here to see how the buld shape is different: http://www.offroadtuff.com/IPFbulbs.htm http://www.4x4rockshop.com/scripts/prodView.asp?idProduct=9596 the ipf is designed for the stock harness (with the relay helping more). adding a higher wattage bulb to a stock harness can work (& probably does for most) but then there's a chance it won't and fry something. speaking of the osram/sylvania sold in us (walmart, etc.) these are not the same as the euro spec one. the us versions have a blue tint (see this tech: http://www.danielsternlighting.com/tech/tech.html ) which is bs, while the euro version is a clear bulb. seems all the mfg make some blue coated bulb in their lineup (ipf does). avoid those models if you can, but as daniel says some are better than others. also the US (1 from walmart, 1 from autozone @ $35/2 bulbs) ones tend to fail to early as 2 of my friends tried em and failed within 6 months. read similar accounts of failure on the web. avoid these blue coated bulbs. if you have em in you will see improvement over stock & they will fail you at some early point. Link to comment
HappyMan Posted October 5, 2005 Author Share Posted October 5, 2005 Wow! I was afraid when I posted this one I'd get yelled at for asking the same question that's been asked a thousand times over. This has been quite helpful and I really appreciate it. I love this forum!! Thanks! Link to comment
eakins Posted October 5, 2005 Share Posted October 5, 2005 I tend to agree with Dave, I went down to WalMart this past weekend and bought a Sylvannia 9003 Halogen H4 lamp, cost me $10.01 out the door, simple change and the light output is 50% better than stock. I tried out a PIAA superwhite, but for $35.00 I sent it back. This cheapo is the way to go. I will put on some another light system, probably motolights in the future. For the price, $10.00, try the WalMart option first. Happy Ridin' these are white lens bulbs and are a great inexpensive option. put a pair in my girlfriends car 2 years ago & still going strong. i don't understand why osram sent crappy blue coated/poor quality xtra visions to the US, while shipping white lens quality xtra vision to europe. Link to comment
Barglowski Posted October 5, 2005 Share Posted October 5, 2005 I went with Sylvania SilverStar, $20 for the H4 at AutoZone. Side-by-side with my buddy's stock RT the difference is noticable. Now I don't have to ride the hi setting just to see the road where there's no streetlights HID conversions aren't street legal, they're expensive, they can be complicated to install (how do you feel about working around high voltage?), and, sorry to say, the idea of getting high and low beams out of a single bulb by physically moving it back and forth strikes me as asking for failure. Not to mention that the reflector on the R1100RT isn't designed for HID bulbs, will scatter light all over the place, and probably annoy every oncoming driver with the glare. Your Mileage May Vary. Valid points. I've asked about the "moving" or "true" H4 HID replacements, but haven't got a good answer yet Why the reflector of the RT is designed for H4 filament positions and the "moving" HID replacement is most likely in the right place, all the versions I've seen have some blocking of one side of the bulb to facilitate the moving of the bulb. If that mechanism reflects the light, it may very well cause unwanted reflections That said, I've also heard that the high beam may be unneeded with the HID bulb, as the low position puts out enough "usable" light. Probably a preference... Lastly, what about the high voltage? Unless you take the ballast apart, the high voltage in the wiring is no less dangerous than the high voltage in your spark plug wires. You better watch out!!! BTW...annoying (getting the notice of) the oncoming driver may be a goal, too! [whine] My personal preferences are not to add external lights to maintain the look of the bike -- I think all those lights hanging off the bike are ugly. If I could put a brighter light in the stock location, take less wattage (35w), and be 3X brighter with being competitive with external lights, I think the HID solution is grand. When you look at the external light solutions, you gotta take in the entire cost: - lights ($$$ or Walmart/AutoZone/Harbour Freight) - mounts ($70+) - wiring harness/switch (at least $20 for something quality) - talent to do it right So...why isn't there a better market for a legal HID replacement! [/whine] I'm still looking on eBay for a good solution, especially when I've got the funds to do it! Later, jan Link to comment
bobgrey Posted October 6, 2005 Share Posted October 6, 2005 After reading a previous post on the forum about extra lights and lighting i looked into the suggested Sylvania Silverstar H4ST bulb. Found them going on eBay for $9.95 + shipping. Just received mine today and tried it tonight. What a differance! Easy way to more light. I'll keep my old bulb as a spare! Link to comment
Rocketman51 Posted October 6, 2005 Share Posted October 6, 2005 Here is a company that has a h-4 HID kit with Hi/Low option. Go to the bottom of the page. Not the system I have. http://www.coolbulbs.com/HIDKits_body.asp Good Luck Link to comment
Rocketman51 Posted October 6, 2005 Share Posted October 6, 2005 Here is another system with Hi/Low HID Bulb. I do have these guys system in my Acura. Has been trouble free for 2 years. http://www.xtralights.com/index.asp?PageAction=VIEWPROD&ProdID=22 Link to comment
