Motorrad4fun Posted October 3, 2005 Share Posted October 3, 2005 I am in need of replacing my brake pads after 13K have not done this before....Any tricks I should be aware of... any help would be great Link to comment
ghaverkamp Posted October 3, 2005 Share Posted October 3, 2005 At 13k, I'm going to assume it's the rears... Pull off the caliber and either forcibly remove the clip in the middle with a pair of pliers (my normal approach, because I always bought a new pin set with my pads) or depress it. Then, using a drift and a mallet (or hammer) slowly tap the pin out from the tapered side of the pin. When that's done, do the other. The pads will slide ride out. My biggest recommendation is to buy the new pin set. It's only $7 or $8, IIRC, and it makes you stress a lot less when once of these pins goes rolling away or your frustration somehow causes the clip to get bent all to hell. Greg Link to comment
Motorrad4fun Posted October 3, 2005 Author Share Posted October 3, 2005 OK great feedback Greg.... Thank You Well, it took all of 20 minutes to do the work. The hardest part was getting the Torque conversion done, that was easy once I found web sitehttp://www.convert-me.com/en/convert/torque Thanks again Link to comment
ghaverkamp Posted October 3, 2005 Share Posted October 3, 2005 Wow, every post I've written today seems to be filled with either grammatical, spelling, or typographical errors. That's no good. Glad you got your brake pads replaced in spite of all of that, rather than, say, spending time looking for your "calibers." Greg Link to comment
