Tank Posted October 3, 2005 Share Posted October 3, 2005 I feel so clumsy... Here's the deal, its raining, cold, and ten cars lined for fuel(it seemed) anyways i fumbled the dang gas nossal, you know the one, with a huge fat rubber slieve,And bumped the gas cap, Turns out that the hinge is just a thin cast part that didn"t weather the abuse.... being Sunday, ordering a replacement is a couple of days off. Has anybody broken this henge before? And if so, Any riddles i should be aware of. Any seals, o-rings that i need to replace with the new cap? Thanks , for any input or friendy ribbing Link to comment
downwind Posted October 3, 2005 Share Posted October 3, 2005 Hey Tank, Ginger broke her gas cap hinge on her '04 R1200C. A&S replaced it under warranty. The mechanic says that it is designed poorly and can break. I take it you are out of warranty? Link to comment
Tank Posted October 3, 2005 Author Share Posted October 3, 2005 Whoa, It never occurded to me about warranty... I need to run that by the extended warranty I bought thru my dealer. Thanks Tom for the heads up on that Link to comment
Clive Liddell Posted October 4, 2005 Share Posted October 4, 2005 Bill, If you end up replacing the cap yourself then I would get a new O-ring because the old one will have expanded due to the fuel splash and fumes. Link to comment
boxercup03 Posted October 4, 2005 Share Posted October 4, 2005 mine broke at the first gas stop of a 1000 mile 24 hr rally,had to duct tape it closed.just be sure to replace the rubber o ring and evenly tourque the allen heads Link to comment
Tank Posted October 5, 2005 Author Share Posted October 5, 2005 That what i was looking for, As i have never needed to trmove the gas cap before i thought that some kind of seal was needed.... o-ring thanks Link to comment
Nevets Posted October 5, 2005 Share Posted October 5, 2005 Mine was bent when I got my RTP, I assume from the cops laying the pump nozzle laying on it. Caused the cap cover to not sit down all the way when it was closed. I was very lucky in that when I took it off the bike, and VERY carefully bent it back straight, it didn't break. Looks fine now, and I'm careful where I lay the pump nozzle. Link to comment
Tank Posted October 5, 2005 Author Share Posted October 5, 2005 Well my service manager, Russel, thought that the warrenty would cover it and hopfully the part will be at Hansan's BMW in Medford, Oregon this friday. As i'm going on a upstate and into Washington ride of about 1500 miles. this is a timely repair. Quick Fix: one hardware store, two metric bolts longer than stock, two one inch finder washers, remove the two bolts opposite the locking mechanism, replace with longer bolt and finder washers. the cap will slide under the washers and than lock. $1.46 Should get me there. Link to comment
KeyLime Posted October 6, 2005 Share Posted October 6, 2005 What the heck is a finder washer?? Link to comment
Tank Posted October 6, 2005 Author Share Posted October 6, 2005 Fender,fender,fender washer.... A finder washer is a washer one finds laying around waiting to be found? Link to comment
KMG_365 Posted October 7, 2005 Share Posted October 7, 2005 Fender,fender,fender washer.... A finder washer is a washer one finds laying around waiting to be found? Don't worry, Tank, I was following you all along . . . but then I speak/read Tankese! I've also heard that with a slight modification (cutting a small notch) the whole gas cap assembly can be turned around to flip AWAY from you. Seems like it would be better that way, so there must be some other reason they all go the OTHER way that I'm just not getting. Link to comment
Blue Beemer Dude Posted October 7, 2005 Share Posted October 7, 2005 I've also heard that with a slight modification (cutting a small notch) the whole gas cap assembly can be turned around to flip AWAY from you. Seems like it would be better that way, so there must be some other reason they all go the OTHER way that I'm just not getting. If it was turned the other way, then it would be backwards! Some highly trained German engineer probably spent weeks working on the gas lid. How dare you presume to know better than he! It's made by German, ja? So it must be correct, ja? Ha! You Americans, you do not understand. We know best. We know what is best for you. Shut up. Give us more of your money. (All in jest, I love Germans) Michael Link to comment
Tank Posted October 10, 2005 Author Share Posted October 10, 2005 All fixed... I just sprung for the $78.00 and drew a crowd in the parking lot changing it out, which means removing tupperware so as to remove old o-ring and refit new o-ring. Extended warrenty had a $50.00 deductable/with a rider that if i don't use it i get my money back, easy gamble without going to Vagas......... Crag Hansan (owner of dealership) slipped out the lock and installed it into the cap when i wasn't looking than smiled as he handed it to me... heh, I really do wish i could have seen the trick to releaseing the lock, oh well. i do hope there won't be a next time. I was so happy to get the cap overnited and the use of their tools in the parking lot I bought the staff lunch Link to comment
KMG_365 Posted October 10, 2005 Share Posted October 10, 2005 All fixed [ . . . ]. I was so happy to get the cap overnited and the use of their tools in the parking lot I bought the staff lunch. WAY Cool!! So, we'll see you in Death Valley in January, then??!! Link to comment
Tank Posted October 11, 2005 Author Share Posted October 11, 2005 Jamie, I have quit unpacking, so i'm ready for DVD in january, All i need from the scouts is where o where are we gonna meet. Wish i could join you later this month, but darn it, i have to ride to Bend, Oregon for a workshop instead. Link to comment
