Uggles Posted September 29, 2005 Share Posted September 29, 2005 I'm thinking about fitting the MCCruise control to my 1150 RT but want to try and integrate the switchgear from the R12RT. A&S don't have a parts list and my dealer can't find it either. Can anyone out there suggest where I may be able to go? Without being too rude of course! Link to comment
Satguy Posted September 29, 2005 Share Posted September 29, 2005 I think the cruise switch setup is the same one BMW uses on the K1200RS, K1200GT etc. You should be able to source one as the K bikes have been around for a while. Cruise control is sure a great feature on those long straight roads... enjoy Link to comment
Clive Liddell Posted September 30, 2005 Share Posted September 30, 2005 Mark, A couple of points (and there are probably 100's more): *The CC requires an electronic speedo drive. *I notice a double throttle cable out the R1200RT, presume that's where the CC pulls the throttle open? So it's all the "gear" from RH side as well? *Not sure where the cut off to the CC is from the brakes but it must be at a common point - brake lamp circuit? All that said I would love to have CC on my RT especially as it cruises easily all day in 5th (top) gear so let us know if your investigations bear fruit, I would be prepared to spend a fair amount anyway. Link to comment
Uggles Posted September 30, 2005 Author Share Posted September 30, 2005 Emailed ya. Oh, and, guys, just to clarify things, the switchgear I'm after is the handlebar mounted stuff. TIA Link to comment
Ken H. Posted September 30, 2005 Share Posted September 30, 2005 There was a discussion about this in this thread awhile back - R1150RT Cruise Thread. The left-hand switch gear from the KGT with cruise is a direct replacement. Also that thread has a picture of the right hand throttle twist where one could connect a pull cable for cruise. The KGT push cable is also a direct fit into the right side. That cable might be made to match up to and aftermarket cruise unit. I was working on the whole idea, but then I wrecked the RT before I got it finished. Link to comment
wilsons Posted September 30, 2005 Share Posted September 30, 2005 This makes me wonder if there is a cruise control option from BMW or anyone else that one could install on a R1200ST? hmmmm... Link to comment
Uggles Posted September 30, 2005 Author Share Posted September 30, 2005 Thanks Ken. I've received a Preliminary (not quite finished) install manual from MCCruise for the 1150RT if anyone is interested and Shawn, it doesn't look to be too far away before yours may be available. Link to comment
