Eckhard Grohe Posted September 21, 2005 Share Posted September 21, 2005 I recently fitted some BT 020's bias ply tires(have an LT rear wheel) to my RT and I notice a vibration that wasn't there before. There was some discussion on this earlier on but I don't remember the outcome. Any remember something about this? Link to comment
Pictou Posted September 22, 2005 Share Posted September 22, 2005 I have no experience with these tires on BMWs but I went through plenty of them on my VFR. I never had any problems with vibration on the VFR. I would be suspicious that you got a bad tire or the wheels aren't balanced correctly. It is not impossible that the tire and bike combination don't like each other for some reason but I would tend to doub that. Having said that my VFR did not like Avons while other VFR owners seemed to be okay with them. Avon tires gave the VFR a nasty headshake. Link to comment
Pictou Posted September 22, 2005 Share Posted September 22, 2005 Oops read your post again and I see you said Bias ply tires. Sorry no experience with those so my comments may not be much good. Link to comment
Boffin Posted September 22, 2005 Share Posted September 22, 2005 I have run BT020-E for 40Kmiles on two different RTs. I have never noticed vibration with them, but that may just be familarity as the only other tyre I have used was an Avon Azaro which, when worn, sounded like a failed wheel bearing. Bad balance seems a possiblity. Cya, Andy Link to comment
