DaJudge Posted September 20, 2005 Share Posted September 20, 2005 My '96 K1100RS started using a great deal more oil in the past 1,500 miles. Friends riding behing report a lot of smoke, most noticibly when I let off from a hard acceleration. I'm told it's lighter in color than what you'd expect from too rich a mixture. Trying to decide if it's more likely valve guides or rings (or something else obvious I haven't thought of !). Any suggestions on a simple test to narrow down the problem? THANKS Link to comment
jrbldr Posted September 20, 2005 Share Posted September 20, 2005 How many miles on the bike? Suggest that you go to: K1100 Owners Group They will undoubtedly have suggestions. If not high miles, it may have something to do with the crankcase venting. Link to comment
ShovelStrokeEd Posted September 20, 2005 Share Posted September 20, 2005 In general, Smoke on acceleration is rings, smoke on trailing throttle is valve guides. It may be as simple as a valve stem oil seal giving up the ghost. That can be repaired with the head on the bike. Pull the plugs and see if its all one cylinder or spread across the gamut. Link to comment
270 Posted September 27, 2005 Share Posted September 27, 2005 In general, Smoke on acceleration is rings, smoke on trailing throttle is valve guides. It may be as simple as a valve stem oil seal giving up the ghost. That can be repaired with the head on the bike. Pull the plugs and see if its all one cylinder or spread across the gamut. What Ed said...but is it really using that much more? Ed, can a failing valve guide seal let THAT much oil through? I really doubt doubt is rings though...smoke on decel=guides normally. Shouldn't be too bad of a fix. Link to comment
ShovelStrokeEd Posted September 28, 2005 Share Posted September 28, 2005 The OP never mentioned, despite the title of his post, how much oil it used, just that it smoked. One failing valve stem seal probably wouldn't effect consumption too much, all of them gone, or worn out guides could certainly do it. You would have a pretty bad smoker though. Link to comment
