Deek Posted November 23, 2009 Share Posted November 23, 2009 I use a "Biker's Friend" backrest/storage roll. In the photo below it can be seen between the top case and my seat. I use it mainly for back support, but it's extremely handy for stowing a rain suit, etc. The problem is it is difficult to attach to the bike. Initially I tried using the RT's "grab rail", but that just made the two attachment straps on each side bunch together and the roll flopped around too much. I have been using two loops of nylon line that go around each of the two top attachment fittings for each saddle bags. Then I run the roll's strap through those two loops on each side and cinch it down as tightly as possible to keep the roll from moving around. It is not a perfect solution, and I'd be satisfied with it if I never removed the saddlebags; but I do have to do that from time to time. Re-attaching the roll is a humongous PITA. My question (finally!): Does anyone know if there is some sort of elegant attachment points that could be installed on the top of the saddlebag, or perhaps on the grab rail or the bike's chassis/body work? That would give me many more options of how to attach the roll. I could just drill a hole in the top of the saddlebags and install a eyelet, but most of the ones I've seen would not be very attractive, and I am also reluctant to drill a hole in the top of the saddlebag since it would surely leak. Any ideas? Surely I am not the only guy out here with such a problem? Thanks! Link to comment
OoPEZoO Posted November 23, 2009 Share Posted November 23, 2009 have a look here LINK Link to comment
johnlt Posted November 23, 2009 Share Posted November 23, 2009 Bungee buddies or bungee loops worked great on the 1150 side cases but the 1200 cases are double-walled so I'm not sure they will work there but you can check it out. Link to comment
Sailorlite Posted November 24, 2009 Share Posted November 24, 2009 I'm thinking that some kind of loop or hook could be attached to the rack itself using 2 or 4 of the torx-head screws which secure the rack to the bike (below the rear seat)... maybe big cable holders from the electrical supply house or Home Depot. Link to comment
JR356 Posted November 24, 2009 Share Posted November 24, 2009 Get some ROK straps,will make your tiedown much easier and more secure. http://www.rokstraps.com/products/products.html You want the long adjustable version. Available at many MC dealers & online. JR356 Link to comment
malcolmblalock Posted November 24, 2009 Share Posted November 24, 2009 The ROK Straps are one of the best inventions for tying things securely on the bike. Have probably used them for 50K miles and never had anything get loose, and they have never left a mark on the bike. I use the hand rails and tie in an "X" pattern, crossing the item being tied down in the middle. Try 'em; you'll like 'em! Link to comment
RoyTemple Posted November 24, 2009 Share Posted November 24, 2009 Hi Deek, I have these attached to the frame under the passenger seat and on the rear rack. I use them to strap things to the passenger seat (with bungies). I normally have the top box on and have now moved the rack straps to the far back openings. When not in use, I put the front ones under the seat. I don't bother but you can tuck the back ones under the top box. Work for me. Roy Link to comment
Deek Posted November 24, 2009 Author Share Posted November 24, 2009 Thanks. That will give me food for thought................... Link to comment
Deek Posted November 24, 2009 Author Share Posted November 24, 2009 ".....but the 1200 cases are double-walled....". Oh, that will be an issue, I'll take a closer look at my cases. Link to comment
Deek Posted November 24, 2009 Author Share Posted November 24, 2009 I think that looks good. I have not thought about using the frame rails under the passenger seat, but I think I like that better than having to drill holes in my side cases. Link to comment
Alan D Posted November 25, 2009 Share Posted November 25, 2009 The ROK Straps are one of the best inventions for tying things securely on the bike. Have probably used them for 50K miles and never had anything get loose, and they have never left a mark on the bike. I use the hand rails and tie in an "X" pattern, crossing the item being tied down in the middle. Try 'em; you'll like 'em! Exactly what I do, works nicely. Link to comment
lvnvbiker Posted November 25, 2009 Share Posted November 25, 2009 I think you could "pop rivet" the bungee buddies to the outer wall of the new style cases. Also I seem to remember that the two parts of the case are able to be seperated, but if not you could drill holes on the inner wall big enough to put the nut and washer in then use rubber/plastic plugs to fill the hole with. Link to comment
