DonW Posted November 9, 2009 Share Posted November 9, 2009 Howdy- I have struggled with using two "fan" type feeler gauge sets to adjust my valves. I want what the pros use- single (or MUCH better- DOUBLE) feeler gauges. Any one know where to buy them?? Thanks, Don Link to comment
thencamebronson Posted November 9, 2009 Share Posted November 9, 2009 Those are Wurth feeler guages, A&S BMW sells them on their website. Link to comment
Selden Posted November 9, 2009 Share Posted November 9, 2009 I bought 2 sets, removed only the blades that I would be using, and created a working set. I just remove the ones I'll be using while adjusting the valves. However, if looking for something better, you might also consider stepped go/no-go gauges. Link to comment
Jeepster Posted November 10, 2009 Share Posted November 10, 2009 I bought my Wurth gauges here LINK Quick, painless service. No affiliation etc. Just a satisfied customer. Link to comment
russell_bynum Posted November 10, 2009 Share Posted November 10, 2009 I bought 2 sets, removed only the blades that I would be using, and created a working set. I just remove the ones I'll be using while adjusting the valves. +1 I bought two sets of the cheap ones, pulled out the pair for the intake and the pair for the exhaust, and riveted each pair together. Link to comment
nrp Posted November 10, 2009 Share Posted November 10, 2009 If you do the conversion and use inch feeler gauges, they only cost about 1/2 or even 1/3 as much for the same gauges. This goes for any metric fasteners too. I would have thought this disparity would be pretty much gone by now. Ah metrification! Link to comment
russell_bynum Posted November 10, 2009 Share Posted November 10, 2009 If you do the conversion and use inch feeler gauges, they only cost about 1/2 or even 1/3 as much for the same gauges. FWIW, The cheap gauges that I got at the local auto parts store are marked in both systems. Link to comment
Wooster Posted November 10, 2009 Share Posted November 10, 2009 I got mine at Bob's BMW (mega dealer in Maryland, I think). Wooster Confusion says "Cat who eats cheese has baited breath" Link to comment
Devo220 Posted November 10, 2009 Share Posted November 10, 2009 You have to be careful with the cheap feeler guages, I have bought them before and they didn't measure what was marked on them. It varied quite alot. I take a 1" micrometer with me to verify sizes before I buy. Link to comment
smiller Posted November 10, 2009 Share Posted November 10, 2009 If you do the conversion and use inch feeler gauges, they only cost about 1/2 or even 1/3 as much for the same gauges. FWIW, The cheap gauges that I got at the local auto parts store are marked in both systems. Yeah, I don't think I've ever even seen a set that didn't have markings in both English and Metric, including a set bought over 30 years ago. Link to comment
russell_bynum Posted November 10, 2009 Share Posted November 10, 2009 You have to be careful with the cheap feeler guages, I have bought them before and they didn't measure what was marked on them. It varied quite alot. I take a 1" micrometer with me to verify sizes before I buy. How much variation have you found? Link to comment
Devo220 Posted November 10, 2009 Share Posted November 10, 2009 As much as the next size guage up and down. You get what you pay for. Link to comment
russell_bynum Posted November 11, 2009 Share Posted November 11, 2009 As much as the next size guage up and down. You get what you pay for. Sure...I definitely will not argue that..but does that much variation even matter when you're setting oilhead valves? My experience has been that as long as they're not too tight, the important thing is to get everything consistent. Link to comment
Peter Parts Posted November 11, 2009 Share Posted November 11, 2009 I agree with Russell B. But I must be living in a different world. For me, the first move is to measure current lash - wouldn't think of looking at valves without doing so. Then you set them. So you need a whole set, even if the go-nogo might be helpful at the end point. Which, in turn, means setting lash pretty carefully, being able to remember where you set them, measuring pretty carefully before doing the next adjustment, and not least, being able to draw proper inferences about your engine's health from the data for each valve. BTW, with my effort to mild-down my over-sporty S, I use Lentini lash, about 2-3 thou over. No, doesn't oblige me to wear hearing protectors because of the racket or turns the valve stems into mushroom shapes (at least not in 30,000 miles with the extra lash). What is general forum opinion on using a spacer to fill the lash-gap on one valve while setting it's twinned valve? I am too clumbsy to do it, but wonder if others favor doing it that way? Link to comment
smiller Posted November 11, 2009 Share Posted November 11, 2009 My experience has been that as long as they're not too tight, the important thing is to get everything consistent. Well if they're too loose then performance can be impacted, but a few thou one way or the other... nah. As you say it's consistency that matters, although if you set things like TB balance after the valve adjustment then even that factor isn't all it's cracked up to be. Look at any shim-adjusted bike, usually anything within a fairly wide window is OK (.004" on the K bikes.) I'm not sure where the legend that oilheads have to be within .0005" came from but it just never seems to die. What is general forum opinion on using a spacer to fill the lash-gap on one valve while setting it's twinned valve? I am too clumbsy to do it, but wonder if others favor doing it that way? This heretic believes that it doesn't matter at all. Link to comment
Stan Walker Posted November 11, 2009 Share Posted November 11, 2009 +1 on just using a single feeler gauge at a time. I don't even own the fancy handled tools, just el-cheapo feeler set from Sears with the two required sizes removed. I do apply a little back pressure on the rocker being adjusted to insure it's all the way open using the hex tool in the screw head. Stan Link to comment
DonW Posted November 11, 2009 Author Share Posted November 11, 2009 For anyone else with the "cheap airhead" heritage I possess, I bought yesterday a feeler gauge set at Sears that includes 2 of each of the sizes we need for our valves (one steel and one brass). It even has a very easy to undo thumbscrew making it easy to remove the units you want. $6.99 + tax Sears #40811 Link to comment
Stan Walker Posted November 12, 2009 Share Posted November 12, 2009 2 of each of the sizes we need for our valves (one steel and one brass). That's the one! I put the brass gauges in my traveling tool kit, and use the steel at home. Stan Link to comment
DonW Posted November 12, 2009 Author Share Posted November 12, 2009 Oh, one more thing. Checked the gauges with my very good micrometer and they are DEAD on. Within .0001 or so. Link to comment
