chrisz Posted September 16, 2005 Share Posted September 16, 2005 Hi, I've made my own Mirror Rescue Wire but can't find a place where to attach them to the mirrors The body part is easy, but nothing seems to be available as an attachment point. Do I have to drill a hole in the plastic? Chris... Link to comment
FREEBEE Posted September 16, 2005 Share Posted September 16, 2005 Do I have to drill a hole in the plastic? I did.... 3/16 just large enough to fit the snap swivel through. Link to comment
chrisz Posted September 16, 2005 Author Share Posted September 16, 2005 Do you think that the plastic where you drilled and attached the wire would hold up if the mirror was knocked off its perch? I'm worried that the plastic would just break off at the wire. Link to comment
FREEBEE Posted September 16, 2005 Share Posted September 16, 2005 I drilled mine close to the center of the plate as opposed to the outer edge. I felt it would give it a bit more "Beef" if you will. Link to comment
J Mart Posted September 16, 2005 Share Posted September 16, 2005 I don't know how you made your wire, but I just use about a 9" fishing leader. To attach to the mirror, I just unscrew one of the Torx screws on the "inside" of the mirror and screw it through the eye loop of the leader. I'm pretty sure it'll hold, but so far haven't tested it (knock on wood). Link to comment
GaryIF Posted September 16, 2005 Share Posted September 16, 2005 Three torx screws attach the black inner frame to the painted outer shell. One of the screws threads into a post, around which you attach the rescue wire. It is necessary to remove all three torx screws so you can separate the inner frame from the outer shell, just enough to slide the rescue wire loop over the post. Having bumped my mirrors off a few times by accident, those wires have paid for themselves multiple times over. Link to comment
flyingreg Posted September 17, 2005 Share Posted September 17, 2005 There is a flange area on the black ABS that is plenty beefy enough for the attachment point. It is really the only place to drill a small hole. No disassembly required and I am sure plenty strong enough to hold the mirror should it get knocked off. This has worked for me thus far. Link to comment
