Marek Posted September 15, 2005 Share Posted September 15, 2005 It seams that I've a little oil on the outside and around Oil Level Window. I'm not sure how it gets there but it must be leaking a little around the window. Has anyone experience the same problem? Link to comment
tomk99r11 Posted September 15, 2005 Share Posted September 15, 2005 Common problem, easy to replace yourself. Dealer replaced one on my 99 and I hadnt noticed any problem with it. That window is just a press fit. Link to comment
Green RT Posted September 17, 2005 Share Posted September 17, 2005 A timely post. Mine also appears to be seeping a little oil as I also have some oil stain around it. I have a spare and will consider replacing it when I change the oil (which is due). Question is: Are there any tricks to this replacement? Is it easy to get the old one out? Is it straightforward to press the new one in? How tight is the fit? Link to comment
Stan Walker Posted September 17, 2005 Share Posted September 17, 2005 Are there any tricks to this replacement? Of course. Lean bike to the right to lower oil level below the window. Use red hot nail to poke hole through plastic window. Turn screw into hole. Pull on screw head to remove window. New sight glass should just press in after cleaning window hole. Stan Link to comment
Green RT Posted September 17, 2005 Share Posted September 17, 2005 Thanks, Stan. Now that you remind me, I remember seeing that trick mentioned here before. Link to comment
leikam Posted September 17, 2005 Share Posted September 17, 2005 Of course doing the swap in the middle of your oil change means you don't need to tilt the bike. Link to comment
Chubber Posted September 20, 2005 Share Posted September 20, 2005 I always scratched my head on the position of the oil sight glass on Oilheads. Does any other motor manufacturer in the world use a pressed in plastic plug below the normal level of the oil? It doesn't even screw in, you just tap it in. Do they ever just pop out, or do they normally just leak until you replace them? I admit, it does give a positive visual feedback that you have the right amount of oil in the engine. But it does seem prone to damage with catastrophic results. Maybe Ill set up a little aftermarket job of making billet covers for them. Link to comment
Marek Posted September 20, 2005 Author Share Posted September 20, 2005 I just got a new one from the dealer - $27. Link to comment
xpict Posted September 20, 2005 Share Posted September 20, 2005 I carry a spare, was told that if I needed one out in the middle of nowhere it would come in handy. Ps. The easy way to check the oil level (I ride a R1100R) is to take out the trusty digital camera and shoot a picture, it works well on the brake fluid level also. No grunting, bending over etc. Link to comment
grizzly660fan Posted September 20, 2005 Share Posted September 20, 2005 in answer to the question about other OEM's using a sight glass? well the answer is yes. I have two Yamaha's with sight glass, and my buddy has a suzuki with sight glass. I have not had any problems with sight glass popping out or leaking with any of my machines (bmw, yamaha, etc) thanks! Link to comment
marcopolo Posted September 20, 2005 Share Posted September 20, 2005 An 1150 GS owner from my local area had his sight glass window come out while riding out west last summer. The part was not stocked locally in the city where he had his bike towed after breaking down and he had to wait 3 days for one to arrive! Moral of that story is a number of us bought and now carry spares with us. That means we'll probably never need it, which is fine with me. Link to comment
Bob Palin Posted September 21, 2005 Share Posted September 21, 2005 I carry a freeze plug for such emergencies. Available everywhere but makes checking the oil level slightly more difficult. Link to comment
Scarecrow Posted September 21, 2005 Share Posted September 21, 2005 Pardon my ignorance, but what's a "freeze plug"? Link to comment
Bob Palin Posted September 21, 2005 Share Posted September 21, 2005 Pardon my ignorance, but what's a "freeze plug"? from the R bike maintenance archive: Popped out oil level window, emergency repair: In a auto parts store (Autozone, NAPA, etc) get a 1.5" adjustable freeze plug. It is hard rubber, with a nut in the center to tighten it. Link to comment
Jim VonBaden Posted September 23, 2005 Share Posted September 23, 2005 I always scratched my head on the position of the oil sight glass on Oilheads. Does any other motor manufacturer in the world use a pressed in plastic plug below the normal level of the oil? It doesn't even screw in, you just tap it in. Do they ever just pop out, or do they normally just leak until you replace them? I admit, it does give a positive visual feedback that you have the right amount of oil in the engine. But it does seem prone to damage with catastrophic results. Maybe Ill set up a little aftermarket job of making billet covers for them. Chris, Take a look at a Ducati, or a Kawasaki KLR 650. They both have a window in the same fashion as the oilhead. Jim Link to comment
